Win xp error code 10
Sysprogs forums Forums WinCDEmu Win xp error code 10
  • #100
    Hi
    I installed WinCdEmu. It’s not working right now. I found the drive letter in the device manager with the error code 10. Tried with different iso files, it’s always the same.
    #1117
    What’s your version of Windows?
    #1118
    It’s XP Professional Version 2002 SP3
    #1119
    Ok, if you mount an image, ensure that an “error code 10” appears in Device Manager, open command prompt and type “net start BazisVirtualCD”, which error message will you get?
    #1120
    It says started service with success (translated from italian). In the Device Manager it says impossible to start the Hardware.
    thanx
    #1121
    LudoA
    I have the exact same error code, and starting the service using “net start …..” works perfectly for me as well. That’s the behavior I get when trying to mount the .cue file.
    If I right-click on the .bin file and open it with wincdemu, it works perfectly. I also described it in http://forum.sysprogs.org/viewtopic.php?f=3&t=159&p=535#p535, as it’s related.
