VS Solution file with main project and unit test project
Sysprogs forums › Forums › VisualGDB › VS Solution file with main project and unit test project
  • #26141
    Markg
    We just started using visual gdb and we want to add unit tests. If I understand the examples correctly we have to create a separate solution file per project:
    Solution file project one (contains production code)
    Solution file project one unit tests (contains unit tests for project one)
    What I rather have is:
    Solution file:
    -Project – production code
    -Project – unit tests
    But if I do it that way it will complain about two main.cpp
    Could you guys help us here?
    #26144
    Sorry for the confusion. Although most of VisualGDB’s tutorials indeed show one project per solution, VisualGDB fully supports having multiple projects in the same solution.
    Please simply right-click on the Solution item in Solution Explorer and select Add->New Project to add a new VisualGDB project (e.g. a unit test project) to the existing solution.
    If it doesn’t work, please let us know and we will help you further.
