VS Clean command fails on relative path
Sysprogs forums › Forums › VisualGDB › VS Clean command fails on relative path
  • #20722
    krs
    I specify the following binary directory: ../../../gwtt_libraries_linux/Debug
    VS Clean command will fail with the following error.
    1>cmd /C del /S /Q ../../../gwtt_libraries_linux/Debug
    1>Invalid switch – “..”.
    1>make: *** [clean] Error 1
    If I use quotes around the binary directory: “../../../gwtt_libraries_linux/Debug”
    Clean command works (But then build fails…)
    Any advice?
    #20741
    Thanks, this is a known limitation of the “del” command. As a workaround, please try setting USE_DEL_TO_CLEAN := 0 in your <config>.mak file (if your toolchain as the rm tool), or simply edit the Makefile to use backward slashes or specify quotes (only in the clean command line).
