VS 2022 Dark Theme Issue
Sysprogs forums › Forums › VisualGDB › VS 2022 Dark Theme Issue
  • #35517
    TRON
    Software installed:
    Visual Studio Community 2022 (64-bit) Version 17.9.6
    VisualGDB 6.0
    I am using the default Dark theme in Visual Studio and in the .vgdbsettings UI editor it is showing various text labels in black instead of white/light-gray making the text illegible.
    I have attached screenshots showing the issue.
    Thanks.
    #35526
    TRON
    To clarify how I encountered the problem is when I double-click on either of the VisualGDB settings\<Project>-<BuildType>.vgdbsettings files it loads the VisualGDB Project Properties panel into a tab.
    I just figured out I can right-click on the project and click “VisualGDB Project Properties” to bring it up as a dialog window instead where it displays correctly.
    I might have been opening it in an unintended manner.
    #35544
    No problem. Both ways to edit settings are supported, there was just a glitch with applying the dark theme when opening it inside the VS file editor.
    We have fixed it in this build: VisualGDB-6.0.101.5173.msi​
    #35552
    TRON
    The update did fix the issue. Thank you!
