VM<->VM kernel debugging
Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › VM<->VM kernel debugging
  • #333
    I am successfully debugging my driver in a VM. My development environment sits (for several reasons) in another VM on the same machine. So far I am using a virtual COM connection between those two machines.
    Is it possible somehow to speed up the debug communication (similar to what VisualKD does but between two VMs)?
    Thanks and best regards,
    Raketa
    #1918
    It is generally possible, but you would need to hack VirtualKD code for that. I could give you more details if you’re interested.
    #1919
    yes, please, it could make my life faster…!
    #1920
    OK, which VM are you using? VirtualBox or VMWare?
    #1921
    its a virtualbox. The host is OSX.
