VisualGDB how to support std c++
Sysprogs forums › Forums › VisualGDB › VisualGDB how to support std c++
  • #715
    Hi!
    in the ndk samples I add #include and get error:
    1>D:codingandroidAndroidProject1jnigraphgraph.h(5,18): fatal error : string: No such file or directory
    how to solved it in VisualGDB?
    #2873
    ket
    You must tell the Android project to use the STL library.
    Please go to VisualGDB Project Properties and on the Makefile settings page choose the STL library version you wish to use (e.g. stlport_shared).
    You can read more about the different STL library versions from docsCPLUSPLUS-SUPPORT.html under your Android NDK install directory.
    #2874
    Thank for reply.
    I solved it by add
    APP_STL := gnustl_static
    in the Application.mk (if there is no Application.mk , you may create one).
    #2875
    ket
    Yes, that is exactly what choosing the STL value in VisualGDB Project Properties does as well.
