VisualGDB Error when creating project – System.InvalidCastException
Sysprogs forums Forums VisualGDB VisualGDB Error when creating project – System.InvalidCastException
  • #12377
    Itamare
    I have installed VisualGDB on Windows 10 – Visual Studio 2017, when trying to create new project i get the error:
    VisualGDB version: 5.2.15.1452
    —————— System.InvalidCastException ——————
    System.InvalidCastException: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE))
    at EnvDTE.SolutionClass.AddFromTemplate(String FileName, String Destination, String ProjectName, Boolean Exclusive)
    at pb.a_2(Solution d, String c, String b, String a, Boolean e)
    at o.a(String b, String a)
    at VisualGDB.Wizard.Embedded.EmbeddedProjectWizardImpl.a_2(wo1 c, String a, String b)
    at u9`1.Execute(Object b, Int32 c, Object[]& a, Object[]& e, wizardResult& d)
    What can cause this issue?
    Itamar
    #12384
    Itamare
    Solved by downgrading to Visual Studio 2015 –
    STM32 – Failed to connect to debug stub
    #12394
    Good to know it works. Normally reinstalling VS2017 and ensuring you can create regular VC++ Win32  projects should help as well (the regular VS wizard uses the same mechanism).
    #12412
    Itamare
    Hi.
    Thanks for the reply, just too many issues with comping the script under VisualGDB, few more issues:
    I am trying to compile and debug a custom board with F446RE on it, using the debugger(ST-LINK) from the Nucleo 446RE, this method absolutely works using SystemWorkbench – code runs perfectly.
    I regenerate the code using CubeMX under GPDSC toolchain/IDE, import to visualGDB – get an error, openocd does not recognize my custom board with 446RE. Is there anything to do with it?
    Thanks.
    • This reply was modified 8 years, 6 months ago by Itamare.
    #12420
    No problem, please follow the instructions in this thread: https://sysprogs.com/w/forums/topic/stm32-failed-to-connect-to-debug-stub/
