Sysprogs forums › Forums › VisualGDB › VisualGDB doesnt allow to specify lib order
- This topic has 3 replies, 2 voices, and was last updated 10 years, 2 months ago by
July 21, 2016 at 11:10 #8683
b.timofte
ParticipantDear all i have this error
/mingw/comp_4.9.2_testversion/bin/g++.exe -o Debug/17_01_Dev.exe -Wl,-Map,MAP.map -Wl,–allow-multiple-definition -LSRC_Code @Debug/17_01_Dev.exe.in -lwinmm -lws2_32 C:\VisualGdb\17_01_Dev\17_01_Dev\SRC_Code\MYLIB.lib -static-libstdc++ -static-libgcc
1> C:\VisualGdb\17_01_Dev\17_01_Dev\SRC_Code\MYLIB.lib(clocklFile.o):clocklFile.cpp: error VGDB1002: undefined reference to `_imp__timeSetEvent@20′
1> C:\VisualGdb\17_01_Dev\17_01_Dev\SRC_Code\MYLIB.lib(clocklFile.o):clocklFile.cpp: error VGDB1002: undefined reference to `_imp__timeKillEvent@4′
1> C:\VisualGdb\17_01_Dev\17_01_Dev\SRC_Code\MYLIB.lib(clocklFile.o):clocklFile.cpp: error VGDB1002: undefined reference to `_imp__timeBeginPeriod@4′
1>collect2.exe : error : ld returned 1 exit statusI think the issue is that i need to put my .lib file before library names winmm ws2_32
VisualGDB doesnt allow this
If i put my lib at library names it uses -l flag and ofcourse it doesnt find it
If i put it in additional linker inputs i get these errors
Is VisualGDB not flexible enough? I cannot imagine no one use in a .lib files from mingw distribution
This topic was modified 10 years, 2 months ago by
b.timofte.
July 21, 2016 at 16:51 #8685support
Normally VisualGDB uses the –begin-group/–end-group options exactly to avoid the need to specify the library order manually.
If you want to specify it manually and not use –begin-group/–end-group, you can do that by removing “winmm” from the “Library Names” field and manually putting the mix of “-lwinmm” and your .lib file in the correct order in the “Additional linker inputs” field.
July 21, 2016 at 22:50 #8687b.timofte
ParticipantI dont know what are you talking about honestly
July 22, 2016 at 01:21 #8688 -
