Visual GDB Version 5 fail
Sysprogs forums › Forums › VisualGDB › Visual GDB Version 5 fail
  • #6796
    wademaxfield
    I upgraded to version 5 of VGDB to support flavors, from version 4.
    Initially, it would not do flavors.  Finally, after several retries, it finally compiled all the flavors attached to the Java project.
    I tried launching from Java and attaching with Visual GDB. It did not attempt to allow me to connect  to the running application, instead it asked me which apk I wanted installed.  After several failures attempting to get it to attach to a running Java program, I finally quit Java and allowed Visual GDB to install the APK I chose.  It then said the toolchain was unfamiliar, and asked if I would run a test program. I said yes.  It failed, and refused to debug.
    I rebooted.  I ran Microsoft Studio 2013 again, re-ran Visual GDB.  This time, it indeed failed the toolchain again, but launched the debugger.  However, I could not pause the debugger nor could I set a breakpoint.  In addition, the “test” program “Stopped” on the emulator.
    So, I would heartily recommend *against* upgrading to version 5, based on my experiences.
    Even if it worked, the new version does not appear to want to let you co-debug with Java, which is what I wanted.  Luckily I can back up to a working version of Visual GDB, though I cannot use flavors with that one.
    #6798
    Sorry to hear that it did not work for you. We have rechecked everything and published a detailed tutorial showing how to debug Gradle flavors here: http://visualgdb.com/tutorials/android/astudio/flavors/
    We have also released VisualGDB 5.0R2 that contains several fixes related to project configurations in VS2015. Please update your VisualGDB before trying the tutorial: http://visualgdb.com/download/
    If this still does not work, please share more details of the problem here or via our support email. We certainly did not intend to break this functionality in v5.0, so if it is broken in any way, we will certainly fix it.
    #6809
    wademaxfield
    MOSTLY FIXED NOW!! TOTALLY USABLE!
    I was contacted after this post by email, in response to my email to support that had been sent a day or two ago.   I am running VS2013.
    The hot fix that was given to me in the email appears to have mostly worked.  I can now build flavors and attach to a running instance, and debug.  The tutorial was great!
    One thing to note, however; the message keeps coming up for every debug: “The current device has not been tested with this toolchain. Do you want to test it now?”
    That test ALWAYS fails.  However, the debugger does indeed work now, it keeps going after that failure to test properly.
    It says to specify the ” or specify linker break point workaround manually via VisualGDB Project properties.”
    The only problem with that is there is *no* linker break point workaround listed in *any* VisualGDB Project properties screen.
    Also, if you bring a project up, and immediately select VisualGDB Project Properties from the menu, it will *not* show up.  It appears you have to select some other things first.  Not sure what.  I assumed it was broken the first three or four times I tried this, and kept restarting VS2013.
    #6810
    You can find the linker workaround option on the Debug Settings page as shown on the screenshot below:
    If the test always keeps on failing, could you please run the extended tests via Android->Device Compatibility Center and send us the logs? Perhaps we could find a different workaround.
    Based on what you have described, most likely normal debugging will work for you, but if you load libraries dynamically, GDB won’t be able to see them until you run “sharedlibrary” manually.
    #6815
    wademaxfield
    Yes, I load libraries dynamically.
    No, I can’t debug my libraries until after I have made a library call, even though the library is in a “static” in a java class.
    It worked in android Studio 1.0 (or thereabouts) and started failing in android 1.2.  I found that I could call any function (I call the “helloworld” string return) to enable debugging in my C/C++ code.
    I thought that was the way it should work, so I never considered it a bug.
    #6816
    wademaxfield
    VisualGDB: Run “c:\android-ndk-r10d\ndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-19 VGDB_VSCONFIG=” in directory “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9” on local computer
    Android NDK: WARNING: APP_PLATFORM android-19 is larger than android:minSdkVersion 3 in ./AndroidManifest.xml
    [armeabi] Gdbserver      : [arm-linux-androideabi-4.8] libs/armeabi/gdbserver
    [armeabi] Gdbsetup       : libs/armeabi/gdb.setup
    [armeabi] Compile thumb  : first <= first.c
    [armeabi] SharedLibrary  : libfirst.so
    [armeabi] Install        : libfirst.so => libs/armeabi/libfirst.so
    [armeabi] Compile thumb  : second <= second.c
    [armeabi] SharedLibrary  : libsecond.so
    [armeabi] Install        : libsecond.so => libs/armeabi/libsecond.so
    VisualGDB: build.xml/local.properties not found in C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9. Running “android update project” to generate it…
    VisualGDB: Run “C:\Users\cti\AppData\Local\Android\sdk\tools\android.bat update project –path “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9″” in directory “” on local computer
    Updated local.properties
    No project name specified, using Activity name ‘SysprogsAndroidAutoTest’.
    If you wish to change it, edit the first line of build.xml.
    Added file C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\build.xml
    Added file C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\proguard-project.txt
    VisualGDB: Run “c:\ant\bin\ant.bat debug” in directory “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9” on local computer
    Buildfile: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\build.xml
    -set-mode-check:
    -set-debug-files:
    -check-env:
    [checkenv] Android SDK Tools Revision 24.3.3
    [checkenv] Installed at C:\Users\cti\AppData\Local\Android\sdk
    -setup:
    [echo] Project Name: SysprogsAndroidAutoTest
    [gettype] Project Type: Application
    -set-debug-mode:
    -debug-obfuscation-check:
    -pre-build:
    -build-setup:
    [getbuildtools] Using latest Build Tools: 21.1.2
    [echo] Resolving Build Target for SysprogsAndroidAutoTest…
    [gettarget] Project Target:   Android 4.4.2
    [gettarget] API level:        19
    [echo] ———-
    [echo] Creating output directories if needed…
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\res
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\rsObj
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\rsLibs
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\gen
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\classes
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\dexedLibs
    [echo] ———-
    [echo] Resolving Dependencies for SysprogsAndroidAutoTest…
    [dependency] Library dependencies:
    [dependency] No Libraries
    [dependency]
    [dependency] ——————
    [echo] ———-
    [echo] Building Libraries with ‘debug’…
    [subant] No sub-builds to iterate on
    -code-gen:
    [mergemanifest] Merging AndroidManifest files into one.
    [mergemanifest] Manifest merger disabled. Using project manifest only.
    [echo] Handling aidl files…
    [aidl] No AIDL files to compile.
    [echo] ———-
    [echo] Handling RenderScript files…
    [echo] ———-
    [echo] Handling Resources…
    [aapt] Generating resource IDs…
    [echo] ———-
    [echo] Handling BuildConfig class…
    [buildconfig] Generating BuildConfig class.
    -pre-compile:
    -compile:
    [javac] Compiling 3 source files to C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\classes
    [javac] warning: [options] source value 1.5 is obsolete and will be removed in a future release
    [javac] warning: [options] target value 1.5 is obsolete and will be removed in a future release
    [javac] warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
    [javac] 3 warnings
    -post-compile:
    -obfuscate:
    -dex:
    [dex] input: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\classes
    [dex] Converting compiled files and external libraries into C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\classes.dex…
    -crunch:
    [crunch] Crunching PNG Files in source dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\res
    [crunch] To destination dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\res
    [crunch] Crunched 0 PNG files to update cache
    -package-resources:
    [aapt] Creating full resource package…
    [aapt] Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
    -package:
    [apkbuilder] Current build type is different than previous build: forced apkbuilder run.
    [apkbuilder] Creating SysprogsAndroidAutoTest-debug-unaligned.apk and signing it with a debug key…
    -post-package:
    -do-debug:
    [zipalign] Running zip align on final apk…
    [echo] Debug Package: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\SysprogsAndroidAutoTest-debug.apk
    [propertyfile] Creating new property file: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\build.prop
    [propertyfile] Updating property file: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\build.prop
    -post-build:
    debug:
    BUILD SUCCESSFUL
    Total time: 2 seconds
    Debug log:
    ——— Testing workaround mode: Disabled, attempt 1 ———
    Preparing for launch…
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell ps
    USER     PID   PPID  VSIZE  RSS     WCHAN    PC         NAME
    root      1     0     848    620   c02ae0fa 0805d0d6 S /init
    root      2     0     0      0     c023187c 00000000 S kthreadd
    root      3     2     0      0     c021faac 00000000 S ksoftirqd/0
    root      4     2     0      0     c022e18d 00000000 S kworker/0:0
    root      5     2     0      0     c022e18d 00000000 S kworker/u:0
    root      6     2     0      0     c022e30f 00000000 S khelper
    root      7     2     0      0     c022e18d 00000000 S kworker/u:1
    root      236   2     0      0     c02883b2 00000000 S sync_supers
    root      238   2     0      0     c028906a 00000000 S bdi-default
    root      240   2     0      0     c022e30f 00000000 S kblockd
    root      248   2     0      0     c022e30f 00000000 S ata_sff
    root      259   2     0      0     c04f3eee 00000000 S khubd
    root      264   2     0      0     c022e30f 00000000 S md
    root      278   2     0      0     c022e30f 00000000 S cfg80211
    root      279   2     0      0     c022e18d 00000000 S kworker/0:1
    root      393   2     0      0     c0282f9a 00000000 S kswapd0
    root      461   2     0      0     c02cd993 00000000 S fsnotify_mark
    root      481   2     0      0     c022e30f 00000000 S crypto
    root      569   2     0      0     c022e30f 00000000 S iscsi_eh
    root      590   2     0      0     c0488c5d 00000000 S mtdblock0
    root      598   2     0      0     c0488c5d 00000000 S mtdblock1
    root      606   2     0      0     c0488c5d 00000000 S mtdblock2
    root      645   2     0      0     c022e18d 00000000 S kworker/0:2
    root      655   2     0      0     c022e18d 00000000 S kworker/u:2
    root      679   2     0      0     c022e30f 00000000 S binder
    root      700   2     0      0     c022e30f 00000000 S deferwq
    root      702   2     0      0     c054f5f9 00000000 S mmcqd/0
    root      705   1     788    396   c02ae0fa 0805d0d6 S /sbin/ueventd
    root      916   2     0      0     c0324722 00000000 S jbd2/mtdblock0-
    root      917   2     0      0     c022e30f 00000000 S ext4-dio-unwrit
    root      921   2     0      0     c02bdfea 00000000 S flush-31:1
    root      923   2     0      0     c0324722 00000000 S jbd2/mtdblock1-
    root      924   2     0      0     c022e30f 00000000 S ext4-dio-unwrit
    root      927   2     0      0     c02bdfea 00000000 S flush-31:2
    root      929   2     0      0     c0324722 00000000 S jbd2/mtdblock2-
    root      930   2     0      0     c022e30f 00000000 S ext4-dio-unwrit
    root      931   1     1572   228   c02d02f9 0805f0bb S /sbin/healthd
    system    932   1     1468   420   c0567827 b774e426 S /system/bin/servicemanager
    root      933   1     6240   1372  ffffffff b76831e1 S /system/bin/vold
    root      935   1     11244  1564  ffffffff b768a1e1 S /system/bin/netd
    root      936   1     1652   516   c0575ad7 b770e7d3 S /system/bin/debuggerd
    radio     937   1     6396   1080  ffffffff b77171e1 S /system/bin/rild
    system    938   1     43504  3076  ffffffff b761bf1b S /system/bin/surfaceflinger
    root      939   1     215408 46532 ffffffff b76de610 S zygote
    drm       940   1     10664  3024  ffffffff b7588426 S /system/bin/drmserver
    media     941   1     28556  6284  ffffffff b7637426 S /system/bin/mediaserver
    install   942   1     1548   560   c05e2abd b76c2fe6 S /system/bin/installd
    keystore  943   1     4720   1436  c0567827 b764e426 S /system/bin/keystore
    root      944   1     1424   440   c02d02f9 b7722f1b S /system/bin/qemud
    shell     947   1     1552   676   c03e88e4 b76e2fe6 S /system/bin/sh
    root      948   1     4772   308   ffffffff 0806ba20 S /sbin/adbd
    system    1254  939   285760 49104 ffffffff b76dff1b S system_server
    u0_a7     1304  939   248152 54196 ffffffff b76dff1b S com.android.systemui
    u0_a2     1338  939   229524 27780 ffffffff b76dff1b S android.process.acore
    u0_a29    1355  939   232952 28960 ffffffff b76dff1b S com.android.inputmethod.latin
    system    1362  939   231800 23260 ffffffff b76dff1b S com.android.settings
    media_rw  1369  1     4032   568   ffffffff b7749fe6 S /system/bin/sdcard
    radio     1393  939   245932 30808 ffffffff b76dff1b S com.android.phone
    u0_a8     1406  939   245496 38564 ffffffff b76dff1b S com.android.launcher
    u0_a39    1421  939   224608 21720 ffffffff b76dff1b S com.android.printspooler
    u0_a5     1448  939   227160 27908 ffffffff b76dff1b S android.process.media
    u0_a6     1476  939   223348 21324 ffffffff b76dff1b S com.android.externalstorage
    u0_a32    1499  939   224952 22984 ffffffff b76dff1b S com.android.music
    u0_a20    1530  939   227036 25492 ffffffff b76dff1b S com.android.deskclock
    u0_a4     1563  939   227148 22624 ffffffff b76dff1b S com.android.dialer
    u0_a1     1583  939   225340 25252 ffffffff b76dff1b S com.android.providers.calendar
    u0_a9     1608  939   236564 25476 ffffffff b76dff1b S com.android.mms
    u0_a16    1634  939   232492 24220 ffffffff b76dff1b S com.android.calendar
    u0_a24    1660  939   234140 28144 ffffffff b76dff1b S com.android.email
    u0_a25    1680  939   227340 22720 ffffffff b76dff1b S com.android.exchange
    u0_a3     1753  939   224516 22876 ffffffff b76dff1b S com.android.defcontainer
    system    1770  939   223516 23792 ffffffff b76dff1b S com.android.keychain
    u0_a37    1784  939   223336 21088 ffffffff b76dff1b S com.svox.pico
    root      2360  948   1868   552   00000000 b7636fe6 R ps
    Command exited with code 0
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell id
    uid=0(root) gid=0(root) context=u:r:shell:s0
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 install -r “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\bin\SysprogsAndroidAutoTest-debug.apk”
    WARNING: linker: libdvm.so has text relocations. This is wasting memory and is a security risk. Please fix.
    pkg: /data/local/tmp/SysprogsAndroidAutoTest-debug.apk
    Success
    138 KB/s (235217 bytes in 1.661s)
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell run-as com.sysprogs.AndroidAutoTest /system/bin/sh -c pwd
    /data/data/com.sysprogs.AndroidAutoTest
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell getprop ro.product.cpu.abi
    x86
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell getprop ro.build.version.sdk
    19
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell ls /data/data/com.sysprogs.AndroidAutoTest/lib
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 shell pm list packages -f
    package:/system/app/SoundRecorder.apk=com.android.soundrecorder
    package:/system/app/SdkSetup.apk=com.android.sdksetup
    package:/system/priv-app/Launcher2.apk=com.android.launcher
    package:/system/priv-app/DefaultContainerService.apk=com.android.defcontainer
    package:/data/app/SmokeTestApp.apk=com.android.smoketest
    package:/system/app/QuickSearchBox.apk=com.android.quicksearchbox
    package:/system/priv-app/Contacts.apk=com.android.contacts
    package:/system/app/LatinIME.apk=com.android.inputmethod.latin
    package:/system/priv-app/TeleService.apk=com.android.phone
    package:/system/app/Calculator.apk=com.android.calculator2
    package:/system/priv-app/ProxyHandler.apk=com.android.proxyhandler
    package:/system/app/HTMLViewer.apk=com.android.htmlviewer
    package:/system/app/ConnectivityTest.apk=com.android.emulator.connectivity.test
    package:/system/priv-app/CalendarProvider.apk=com.android.providers.calendar
    package:/system/priv-app/InputDevices.apk=com.android.inputdevices
    package:/system/app/CustomLocale.apk=com.android.customlocale2
    package:/system/app/Calendar.apk=com.android.calendar
    package:/system/app/Browser.apk=com.android.browser
    package:/system/app/Music.apk=com.android.music
    package:/system/app/NetSpeed.apk=com.android.netspeed
    package:/data/app/WidgetPreview.apk=com.android.widgetpreview
    package:/data/app/CubeLiveWallpapers.apk=com.example.android.livecubes
    package:/system/app/DownloadProviderUi.apk=com.android.providers.downloads.ui
    package:/system/app/UserDictionaryProvider.apk=com.android.providers.userdictionary
    package:/system/app/DocumentsUI.apk=com.android.documentsui
    package:/system/app/PinyinIME.apk=com.android.inputmethod.pinyin
    package:/system/priv-app/SharedStorageBackup.apk=com.android.sharedstoragebackup
    package:/system/priv-app/VpnDialogs.apk=com.android.vpndialogs
    package:/system/priv-app/Mms.apk=com.android.mms
    package:/system/app/PacProcessor.apk=com.android.pacprocessor
    package:/system/priv-app/MediaProvider.apk=com.android.providers.media
    package:/system/app/CertInstaller.apk=com.android.certinstaller
    package:/data/app/ApiDemos.apk=com.example.android.apis
    package:/data/app/com.sysprogs.AndroidAutoTest-2.apk=com.sysprogs.AndroidAutoTest
    package:/system/app/PrintSpooler.apk=com.android.printspooler
    package:/system/app/Fallback.apk=com.android.fallback
    package:/data/app/GestureBuilder.apk=com.android.gesture.builder
    package:/system/app/Gallery.apk=com.android.gallery
    package:/system/framework/framework-res.apk=android
    package:/system/priv-app/Settings.apk=com.android.settings
    package:/system/priv-app/ContactsProvider.apk=com.android.providers.contacts
    package:/system/app/Protips.apk=com.android.protips
    package:/system/priv-app/ExternalStorageProvider.apk=com.android.externalstorage
    package:/system/app/BasicDreams.apk=com.android.dreams.basic
    package:/system/app/DevelopmentSettings.apk=com.android.development_settings
    package:/data/app/SoftKeyboard.apk=com.example.android.softkeyboard
    package:/system/app/Exchange2.apk=com.android.exchange
    package:/system/priv-app/SystemUI.apk=com.android.systemui
    package:/system/app/LiveWallpapersPicker.apk=com.android.wallpaper.livepicker
    package:/system/app/SpeechRecorder.apk=com.android.speechrecorder
    package:/system/app/KeyChain.apk=com.android.keychain
    package:/system/app/GpsLocationTest.apk=com.android.emulator.gps.test
    package:/system/app/PackageInstaller.apk=com.android.packageinstaller
    package:/system/app/Development.apk=com.android.development
    package:/data/app/SmokeTest.apk=com.android.smoketest.tests
    package:/system/app/TelephonyProvider.apk=com.android.providers.telephony
    package:/system/app/PicoTts.apk=com.svox.pico
    package:/system/app/LegacyCamera.apk=com.android.camera
    package:/system/app/OpenWnn.apk=jp.co.omronsoft.openwnn
    package:/system/app/Email.apk=com.android.email
    package:/system/priv-app/Dialer.apk=com.android.dialer
    package:/system/app/DeskClock.apk=com.android.deskclock
    package:/system/priv-app/FusedLocation.apk=com.android.location.fused
    package:/system/priv-app/BackupRestoreConfirmation.apk=com.android.backupconfirm
    package:/system/priv-app/SettingsProvider.apk=com.android.providers.settings
    package:/system/priv-app/Keyguard.apk=com.android.keyguard
    package:/system/priv-app/Shell.apk=com.android.shell
    package:/system/priv-app/DownloadProvider.apk=com.android.providers.downloads
    Exception: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\libs\x86\gdbserver does not exist!
    ——— Testing workaround mode: EnabledWithEvenAddress, attempt 1 ———
    system    1254  939   285780 49128 ffffffff b76dff1b S system_server
    u0_a7     1304  939   248152 54200 ffffffff b76dff1b S com.android.systemui
    u0_a2     1338  939   229524 27788 ffffffff b76dff1b S android.process.acore
    u0_a8     1406  939   245480 38560 ffffffff b76dff1b S com.android.launcher
    u0_a3     1753  939   224516 22904 ffffffff b76dff1b S com.android.defcontainer
    system    1770  939   223572 23808 ffffffff b76dff1b S com.android.keychain
    u0_a37    1784  939   223456 21612 ffffffff b76dff1b S com.svox.pico
    root      2399  948   1868   548   00000000 b76e8fe6 R ps
    Success
    1304 KB/s (235217 bytes in 0.176s)
    x86
    19
    package:/data/app/com.sysprogs.AndroidAutoTest-1.apk=com.sysprogs.AndroidAutoTest
    ——— Testing workaround mode: EnabledWithOddAddress, attempt 1 ———
    system    1254  939   285780 49144 ffffffff b76dff1b S system_server
    u0_a2     1338  939   229524 27796 ffffffff b76dff1b S android.process.acore
    u0_a29    1355  939   232952 28964 ffffffff b76dff1b S com.android.inputmethod.latin
    u0_a8     1406  939   245488 38572 ffffffff b76dff1b S com.android.launcher
    u0_a3     1753  939   224516 22928 ffffffff b76dff1b S com.android.defcontainer
    root      2438  948   1868   548   00000000 b764cfe6 R ps
    Success
    1495 KB/s (235217 bytes in 0.153s)
    x86
    19
    Debug failed: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.9\libs\x86\gdbserver does not exist!
    #6817
    wademaxfield
    VisualGDB: Run “c:\android-ndk-r10d\ndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-19 VGDB_VSCONFIG=” in directory “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8” on local computer
    VisualGDB: build.xml/local.properties not found in C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8. Running “android update project” to generate it…
    VisualGDB: Run “C:\Users\cti\AppData\Local\Android\sdk\tools\android.bat update project –path “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8″” in directory “” on local computer
    Added file C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\build.xml
    Added file C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\proguard-project.txt
    VisualGDB: Run “c:\ant\bin\ant.bat debug” in directory “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8” on local computer
    Buildfile: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\build.xml
    -set-mode-check:
    -set-debug-files:
    -check-env:
    -setup:
    -set-debug-mode:
    -pre-build:
    -build-setup:
    [echo] ———-
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\res
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\rsObj
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\rsLibs
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\gen
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\classes
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\dexedLibs
    [echo] ———-
    [dependency]
    [dependency] ——————
    [echo] ———-
    -code-gen:
    [echo] ———-
    [echo] ———-
    [echo] ———-
    -pre-compile:
    -compile:
    [javac] Compiling 3 source files to C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\classes
    [javac] 3 warnings
    -post-compile:
    -obfuscate:
    -dex:
    [dex] input: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\classes
    [dex] Converting compiled files and external libraries into C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\classes.dex…
    -crunch:
    [crunch] Crunching PNG Files in source dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\res
    [crunch] To destination dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\res
    -package-resources:
    -package:
    -post-package:
    -do-debug:
    [echo] Debug Package: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\SysprogsAndroidAutoTest-debug.apk
    [propertyfile] Creating new property file: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\build.prop
    [propertyfile] Updating property file: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\build.prop
    -post-build:
    debug:
    BUILD SUCCESSFUL
    Debug log:
    system    1254  939   285760 48992 ffffffff b76dff1b S system_server
    u0_a7     1304  939   248152 54192 ffffffff b76dff1b S com.android.systemui
    u0_a2     1338  939   229524 27776 ffffffff b76dff1b S android.process.acore
    u0_a29    1355  939   232952 28944 ffffffff b76dff1b S com.android.inputmethod.latin
    system    1362  939   231800 23256 ffffffff b76dff1b S com.android.settings
    radio     1393  939   245932 30788 ffffffff b76dff1b S com.android.phone
    u0_a8     1406  939   245496 38540 ffffffff b76dff1b S com.android.launcher
    u0_a9     1608  939   236564 25460 ffffffff b76dff1b S com.android.mms
    u0_a3     1753  939   224400 22732 ffffffff b76dff1b S com.android.defcontainer
    system    1770  939   223516 23940 ffffffff b76dff1b S com.android.keychain
    u0_a37    1784  939   223336 21084 ffffffff b76dff1b S com.svox.pico
    root      2245  948   1868   544   00000000 b7671fe6 R ps
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 install -r “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\bin\SysprogsAndroidAutoTest-debug.apk”
    Success
    155 KB/s (235217 bytes in 1.481s)
    x86
    19
    Exception: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\libs\x86\gdbserver does not exist!
    system    1254  939   285760 49000 ffffffff b76dff1b S system_server
    u0_a29    1355  939   232952 28952 ffffffff b76dff1b S com.android.inputmethod.latin
    radio     1393  939   245932 30792 ffffffff b76dff1b S com.android.phone
    u0_a8     1406  939   245480 38548 ffffffff b76dff1b S com.android.launcher
    u0_a3     1753  939   224516 22784 ffffffff b76dff1b S com.android.defcontainer
    system    1770  939   223636 24012 ffffffff b76dff1b S com.android.keychain
    root      2283  948   1868   548   00000000 b767ffe6 R ps
    Success
    145 KB/s (235217 bytes in 1.576s)
    x86
    19
    system    1254  939   291596 51232 ffffffff b76dff1b S system_server
    u0_a29    1355  939   232952 28956 ffffffff b76dff1b S com.android.inputmethod.latin
    u0_a8     1406  939   245488 38556 ffffffff b76dff1b S com.android.launcher
    u0_a3     1753  939   224516 22856 ffffffff b76dff1b S com.android.defcontainer
    root      2322  948   1868   552   00000000 b76a4fe6 R ps
    Success
    1338 KB/s (235217 bytes in 0.171s)
    x86
    19
    Debug failed: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.8\libs\x86\gdbserver does not exist!
    #6818
    wademaxfield
    VisualGDB: Run “c:\android-ndk-r10d\ndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-19 VGDB_VSCONFIG=” in directory “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6” on local computer
    VisualGDB: build.xml/local.properties not found in C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6. Running “android update project” to generate it…
    VisualGDB: Run “C:\Users\cti\AppData\Local\Android\sdk\tools\android.bat update project –path “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6″” in directory “” on local computer
    Added file C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\build.xml
    Added file C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\proguard-project.txt
    VisualGDB: Run “c:\ant\bin\ant.bat debug” in directory “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6” on local computer
    Buildfile: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\build.xml
    -set-mode-check:
    -set-debug-files:
    -check-env:
    -setup:
    -set-debug-mode:
    -pre-build:
    -build-setup:
    [echo] ———-
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\res
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\rsObj
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\rsLibs
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\gen
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\classes
    [mkdir] Created dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\dexedLibs
    [echo] ———-
    [dependency]
    [dependency] ——————
    [echo] ———-
    -code-gen:
    [echo] ———-
    [echo] ———-
    [echo] ———-
    -pre-compile:
    -compile:
    [javac] Compiling 3 source files to C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\classes
    [javac] 3 warnings
    -post-compile:
    -obfuscate:
    -dex:
    [dex] input: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\classes
    [dex] Converting compiled files and external libraries into C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\classes.dex…
    -crunch:
    [crunch] Crunching PNG Files in source dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\res
    [crunch] To destination dir: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\res
    -package-resources:
    -package:
    -post-package:
    -do-debug:
    [echo] Debug Package: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\SysprogsAndroidAutoTest-debug.apk
    [propertyfile] Creating new property file: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\build.prop
    [propertyfile] Updating property file: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\build.prop
    -post-build:
    debug:
    BUILD SUCCESSFUL
    Total time: 1 second
    Debug log:
    system    1254  939   285616 48104 ffffffff b76dff1b S system_server
    u0_a7     1304  939   248092 54180 ffffffff b76dff1b S com.android.systemui
    u0_a2     1338  939   229524 27772 ffffffff b76dff1b S android.process.acore
    u0_a29    1355  939   232952 28936 ffffffff b76dff1b S com.android.inputmethod.latin
    radio     1393  939   245812 30584 ffffffff b76dff1b S com.android.phone
    u0_a8     1406  939   245488 38528 ffffffff b76dff1b S com.android.launcher
    u0_a5     1448  939   227160 27904 ffffffff b76dff1b S android.process.media
    u0_a25    1680  939   227340 22716 ffffffff b76dff1b S com.android.exchange
    u0_a3     1753  939   223656 22848 ffffffff b76dff1b S com.android.defcontainer
    system    1770  939   223516 23648 ffffffff b76dff1b S com.android.keychain
    u0_a37    1784  939   223336 21076 ffffffff b76dff1b S com.svox.pico
    root      2128  948   1868   548   00000000 b76ebfe6 R ps
    C:\Users\cti\AppData\Local\Android\sdk\platform-tools\adb.exe -s emulator-5554 install -r “C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\bin\SysprogsAndroidAutoTest-debug.apk”
    Success
    136 KB/s (235217 bytes in 1.680s)
    x86
    19
    Exception: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\libs\x86\gdbserver does not exist!
    system    1254  939   285728 48880 ffffffff b76dff1b S system_server
    u0_a29    1355  939   232952 28940 ffffffff b76dff1b S com.android.inputmethod.latin
    u0_a8     1406  939   245480 38524 ffffffff b76dff1b S com.android.launcher
    u0_a3     1753  939   224696 23032 ffffffff b76dff1b S com.android.defcontainer
    system    1770  939   223516 23676 ffffffff b76dff1b S com.android.keychain
    root      2168  948   1868   548   00000000 b76c0fe6 R ps
    Success
    182 KB/s (235217 bytes in 1.255s)
    x86
    19
    system    1254  939   286532 49300 ffffffff b76dff1b S system_server
    u0_a8     1406  939   245488 38532 ffffffff b76dff1b S com.android.launcher
    system    1770  939   223516 23748 ffffffff b76dff1b S com.android.keychain
    u0_a37    1784  939   223336 21080 ffffffff b76dff1b S com.svox.pico
    root      2206  948   1868   548   00000000 b76dafe6 R ps
    Success
    895 KB/s (235217 bytes in 0.256s)
    x86
    19
    Debug failed: C:\Users\cti\AppData\Local\Temp\SysprogsAndroidTest-3848\4.6\libs\x86\gdbserver does not exist!
