Visual GDB importing existing embedded project with modular firmware
Sysprogs forums › Forums › VisualGDB › Visual GDB importing existing embedded project with modular firmware
  • #9132
    billskeen68
    I really like VisualGDB. Great product, ready to click on Buy. I haven’t done embedded debugging since the `80s using an Intel ICE system. Wow, have times changed. Sorry, I regress.
    I want to use VisualGDB to debug RedBear Duo firmware to capture a hard fault in my application. I have been successful at importing the application – user-part; building a debug version and debugging (openOCD & VGDB). What I have no clue about is how to add the two firmware components, system-part1 & system-part2 to this solution as the make/build process is a bit confusing. The hard fault handler is in the system-part2.
    Is there a tutorial or other place you can point me to that describes how to import something like this? If not, any suggestions on how I should proceed.
    If purchasing VisualGDB before support is required, I will do so immediately.
    Bill
    #9141
    We do have a tutorial explaining how to create a basic bootloader with VisualGDB: http://visualgdb.com/tutorials/arm/bootloader/
    Hopefully this clarifies the necessary steps. If not, feel free to ask further questions here and we will do our best to help you.
