VirtualKD VMInstall bug
Sysprogs forums Forums Other tools & products VirtualKD VMInstall bug
  • #111
    Hi there,
    I have never been able to successfully install VirtualKD on the target using the installer targetvminstall.exe, I always seemed to get “Error – cannot access boot configuration data”.
    Tired of this failing on multiple versions, I decided to build and debug it myself rather than submitting a query. I have solved the problem, here I detail the bug(?) and solution:
    In bootedit.cpp on line 546 is the following test:
    if (!m_OSEntries.empty() && !m_Default.GetValue().empty() && !m_Timeout.GetValue().empty())
    m_bValid = true;
    This test was failing, leaving m_bValid false, causing the error. I narrowed it down to the return from m_Default.GetValue().empty(), and discovered this was erroneously returning that m_Default was empty.
    In my boot.ini I noticed that the ‘default’ line begins with a forward slash (/default), I assume this is the case for everyone. I then noticed that line 536 had the test:
    else if (!key.icompare(“default”))
    and line 534 has:
    if (!key.icompare(“timeout”))
    Now the timeout line has no forward-slash, so without wanting to waste further time debugging the key.icompare function, I decided to try changing line 536 to:
    else if (!key.icompare(“/default”))
    This worked and fixed the installer for me, so I assume this function was failing because of the forward slash. I can’t fathom how it could have worked for other people (XP SP2 guest) but I can’t afford to spend any more time on this.
    I hope this might be helpful for others.
    Kind regards,
    Kev
    #1175
    I’ve just noticed that on other machines, the forward slash is missing. Not sure what’s going on here, but it seems to be present in only *some* systems… or only my system?!
    Bit of a mystery, I assume therefore that I’m in the minority with the forward slash before ‘default’ but if any body else has this problem I guess you can just remove the forward slash!
    Sorry for wasting your time if my forward slash was unique 😳
    kev
    #1176
    The forward slash seems to be your unique case (some third-party boot manager?). Anyway, I’ll add support for both “default” and “/default” in the future versions. Thanks for investigating the problem πŸ˜‰
    #1177
    stifenhowk
    Hello kevoreilly.
    I read your entire problem if you are change your hardware then it will be install and first check your all drives with good anti-virus.
