VGDB fails to extract version from MCUXpresso SDK
Sysprogs forums Forums VisualGDB VGDB fails to extract version from MCUXpresso SDK
  • #28789
    UdoEberhardt
    I’m using VGDB 5.5.7.3703. When I import a recent NXP MCUXpresso SDK, e.g. SDK_2.8.0_MIMXRT1061xxxxA.zip, then VGDB seems not to be able to determine the version number. The BSP.XML file it generates contains:
    <PackageID>com.sysprogs.imported.ksdk2x.MIMXRT1062xxxxA</PackageID>
    <PackageDescription>Imported MCUXpresso SDK for MIMXRT1062xxxxA</PackageDescription>
    <PackageVersion>unknown</PackageVersion>
    For your reference, I attached the manifest XML of that SDK.
    When I import the same SDK with VGDB 5.5.2 then it correctly shows version “2.8.0”.
    Thanks for looking into this. Let me know if you need more info.
    Regards,
    Udo
    #28793
    Sorry, looks like the file did not get attached properly. Do you mind packing it into a zip file and attaching it again?
    #28817
    UdoEberhardt
    Here is the zipped xml.
    #28833
    No problem, we have updated the version parsing logic in this build: VisualGDB-5.5.8.3747.msi
    #28841
    UdoEberhardt
    I confirm the issue is fixed in VisualGDB-5.5.8.3747. Thank you very much for your great support!
    Udo
