I downloaded 5.4 (Preview 10, later I did Beta 1), and just tried to “Create a new App with a simple native library”, using Gradle as the builder. I choose Android 8.1, SDK platform: android-27, and NDK platform: android-27, and click Finish.
It does the setup just fine. Then a few odd things when I go to build I get:
Starting a Gradle Daemon, 1 busy and 2 incompatible and 4 stopped Daemons could not be reused, use –status for details
FAILURE: Build failed with an exception.
* What went wrong:
A problem occurred configuring project ‘:app’.
> NDK not configured.
Download it with SDK manager.
So I go to VisualGDB Project Properties, and I see the “Targeted Android NDK platform is set to “Android-8” (why? I told it I wanted android-27 before) So I set it to Android-27 in the drop-down menu.
I get the same error. My NDK, Android SDK, etc are all set up properly. Everything works perfectly when I use the ANT method.
Keep up the good work! I look forward to future versions and improvements!
Also wanted to underline what I’m seeing with more and more gradle daemons getting started. Doesn’t seem to just use a single gradle daemon, they keep piling up. Thanks for any advice.
