VERR_PDM_INVALID_DEVICE_GUEST_BITS Error using Virtual KD
Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › VERR_PDM_INVALID_DEVICE_GUEST_BITS Error using Virtual KD
  • #437
    SnowProblem
    I followed the tutorial (http://virtualkd.sysprogs.org/tutorials/install/) but unfortunately it is not working for me. After running VirtualKDSetup.exe, I can no longer start VMs anymore. Here is a screenshot of the error dialog when I try to start a VM: http://imgur.com/1PHLj
    I am running Windows 7 32-bit, VirtualBox 4.1.20, and Virtual KD 2.8 if that helps.
    Also, from VBox.log:
    00:00:00.459 PDM: Rejected device ‘VirtualKD’ because it didn’t match the guest bits.
    00:00:00.461 VMSetError: E:tinderboxwin-relsrcVBoxVMMVMMR3VM.cpp(362) VMR3Create; rc=VERR_PDM_INVALID_DEVICE_GUEST_BITS
    00:00:00.461 VMSetError: Invalid host bit mask.
    00:00:00.461 ERROR [COM]: aRC=E_FAIL (0x80004005) aIID={1968b7d3-e3bf-4ceb-99e0-cb7c913317bb} aComponent={Console} aText={Invalid host bit mask. (VERR_PDM_INVALID_DEVICE_GUEST_BITS)}, preserve=false
    00:00:00.503 Power up failed (vrc=VERR_PDM_INVALID_DEVICE_GUEST_BITS, rc=E_FAIL (0X80004005))
    Any ideas/suggestions on how to fix this? I would really like to give VirtualKD a try! Thanks.
    #2095
    Please try registering the 32-bit version of VBoxKD.DLL
    #2097
    omich
    Hello, I got the same error.
    I tried to use regsvr32.exe and it reported that registration finished sucessful, but it wasn’t usefull: the problem is still there. I use Windows 7 SP1 with Virtual Box 4.1.22 and VirtualKD 2.8.
    Could you please help me?
    #2096
    This worked for me:
    – Uninstall VirtualBox
    – delete c:Program FilesOraceVirtualBox directory
    – delete c:Documents and Settings.VirtualBox directory
    – Reinstall VirtualBox
    – Reintegrate VirtualKd
    #2099
    ronaldinho
    @kdhelp wrote:
    This worked for me:
    Many days ago one time i try this way ,it works,but now even i install a fresh windows 7 or 8,and virtualbox 4.1.26 or 4.1.24 or 4.1.8 and so on,it always show VERR_PDM_INVALID_DEVICE_GUEST_BITS ,why ??? i am about crazy ,somebody help me?
    #2100
    ronaldinho
    i try all the way above but i cannot run a VM! now i even try install a new fresh windows 7 32bit or 8 32bit ,i try all the 4.1.x version ,it donot work ether.
    what ever i do ,it always show me:
    不能为虚拟电脑 xxx 打开一个新任务.
    Invalid host bit mask. (VERR_PDM_INVALID_DEVICE_GUEST_BITS).
    返回 代码:E_FAIL (0x80004005)
    组件:Console
    界面:IConsole {1968b7d3-e3bf-4ceb-99e0-cb7c913317bb}
    can somebody help me ?
    #2098
    FeyFre
    EDIT: Removed. False alarm. I using VBox v>4.1 which is not supported yet.
    #2101
    I am getting the same thing.
    I had originally had VirtualBox 4.2 installed — there I got a class-cast exception.
    However, I installed 4.1.32r92798, and started getting the VERR_PDM_INVALID_DEVICE_GUEST_BITS error.
    I tried the uninstall/delete Program FilesOracleVirtualBox / delete UsersYourUser.VirtualBox directory / reinstall as suggested above, but after reinstalling and re-integrating VirtualKD, I get the same error.
    This is a 32-bit Win7 host, running (or rather, attempting to run) a 32-bit Win7 guest. The guest worked prior to integrating VirtualKD, and worked after re-installing VirtualBox (but before re-integrating VirtualKD).
    #2102
    Update:
    I also tried re-integrating without elevating the setup EXE; same effect. After noticing a second error in the logs — access denied — I also tried elevating the VirtualBox process itself…but I still get the same error.
    This is my log file:
    VirtualBox 4.1.32 r92798 win.x86 (Mar 13 2014 21:46:15) release log
    00:00:03.006 Log opened 2014-06-05T17:17:29.020251600Z
    00:00:03.006 OS Product: Windows 7
    00:00:03.006 OS Release: 6.1.7601
    00:00:03.006 OS Service Pack: 1
    00:00:03.008 Host RAM: 3060MB RAM, available: 1434MB
    00:00:03.008 Executable: C:Program FilesOracleVirtualBoxVirtualBox.exe
    00:00:03.008 Process ID: 4568
    00:00:03.008 Package type: WINDOWS_32BITS_GENERIC
    00:00:03.008 Installed Extension Packs:
    00:00:03.008   None installed!
    00:00:03.132 SUP: Loaded VMMR0.r0 (C:Program FilesOracleVirtualBoxVMMR0.r0) at 0x8d547000 - ModuleInit at 000000008d55d080 and ModuleTerm at 000000008d55d340 using the native ring-0 loader
    00:00:03.132 SUP: VMMR0EntryEx located at 000000008d55e210, VMMR0EntryFast at 000000008d55d4e0 and VMMR0EntryInt at 000000008d55d4d0
    00:00:03.132 SUP: windbg> .reload /f C:Program FilesOracleVirtualBoxVMMR0.r0=0x8d547000
    00:00:03.137 OS type: 'Windows7'
    00:00:03.154 File system of 'C:UsersMyUserNameVirtualBox VMsIE11 - Win7Snapshots' (snapshots) is ntfs
    00:00:03.154 File system of 'C:UsersMyUserNameVirtualBox VMsIE11 - Win7Snapshots/{eaddf2cb-36c5-4ff7-b148-487b1613dc92}.vmdk' is ntfs
    00:00:03.244 ************************* CFGM dump *************************
    00:00:03.244 [/] (level 0)
    00:00:03.244 CSAMEnabled = 0x0000000000000001 (1)
    00:00:03.244 CpuExecutionCap
    = 0x0000000000000064 (100)
    00:00:03.244 EnablePAE
    = 0x0000000000000000 (0)
    00:00:03.244 HwVirtExtForced
    00:00:03.244 MemBalloonSize
    00:00:03.244 Name = "IE11 - Win7" (cb=12)
    00:00:03.244 NumCPUs = 0x0000000000000001 (1)
    00:00:03.244 PATMEnabled
    00:00:03.244 PageFusion
    00:00:03.244 RamHoleSize
    = 0x0000000020000000 (536 870 912, 512 MB)
    00:00:03.244 RamSize
    00:00:03.244 RawR0Enabled
    00:00:03.244 RawR3Enabled
    00:00:03.244 TimerMillies
    = 0x000000000000000a (10)
    00:00:03.244 UUID = "78 6a 23 13 fd ae 1f 43 b7 45 74 60 21 90 0c c0" (cb=16)
    00:00:03.244
    00:00:03.244 [/CPUM/] (level 1)
    00:00:03.244 SyntheticCpu = 0x0000000000000000 (0)
    00:00:03.244
    00:00:03.244 [/Devices/] (level 1)
    00:00:03.244
    00:00:03.244 [/Devices/8237A/] (level 2)
    00:00:03.244
    00:00:03.244 [/Devices/8237A/0/] (level 3)
    00:00:03.244 Trusted
    00:00:03.244
    00:00:03.244 [/Devices/AudioSniffer/] (level 2)
    00:00:03.244
    00:00:03.244 [/Devices/AudioSniffer/0/] (level 3)
    00:00:03.244
    00:00:03.244 [/Devices/AudioSniffer/0/Config/] (level 4)
    00:00:03.244
    00:00:03.244 [/Devices/AudioSniffer/0/LUN#0/] (level 4)
    00:00:03.244 Driver = "MainAudioSniffer" (cb=17)
    00:00:03.244
    00:00:03.244 [/Devices/AudioSniffer/0/LUN#0/Config/] (level 5)
    00:00:03.244 Object = 0x0000000002112010 (34 676 752)
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/] (level 2)
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/0/] (level 3)
    00:00:03.244 PCIBusNo
    00:00:03.244 PCIDeviceNo
    = 0x0000000000000004 (4)
    00:00:03.244 PCIFunctionNo
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/0/Config/] (level 4)
    00:00:03.244 GuestCoreDumpDir = "C:UsersMyUserNameVirtualBox VMsIE11 - Win7Snapshots" (cb=53)
    00:00:03.244 RamSize = 0x0000000020000000 (536 870 912, 512 MB)
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/0/LUN#0/] (level 4)
    00:00:03.244 Driver = "HGCM" (cb=5)
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/0/LUN#0/Config/] (level 5)
    00:00:03.244 Object = 0x0000000003365fe0 (53 895 136)
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/0/LUN#999/] (level 4)
    00:00:03.244 Driver = "MainStatus" (cb=11)
    00:00:03.244
    00:00:03.244 [/Devices/VMMDev/0/LUN#999/Config/] (level 5)
    00:00:03.244 First = 0x0000000000000000 (0)
    00:00:03.244 Last
    00:00:03.244 papLeds
    = 0x0000000002113488 (34 681 992)
    00:00:03.244
    00:00:03.244 [/Devices/VirtualKD/] (level 2)
    00:00:03.244
    00:00:03.244 [/Devices/VirtualKD/0/] (level 3)
    00:00:03.244 Name = "Default" (cb=8)
    00:00:03.244
    00:00:03.244 [/Devices/acpi/] (level 2)
    00:00:03.244
    00:00:03.244 [/Devices/acpi/0/] (level 3)
    00:00:03.244 PCIBusNo = 0x0000000000000000 (0)
    = 0x0000000000000007 (7)
    00:00:03.244
    00:00:03.244 [/Devices/acpi/0/Config/] (level 4)
    00:00:03.244 CpuHotPlug
    00:00:03.244 FdcEnabled
    00:00:03.244 HostBusPciAddress
    00:00:03.244 HpetEnabled
    00:00:03.244 IOAPIC
    00:00:03.244 IocPciAddress
    = 0x0000000000010000 (65 536)
    00:00:03.244 Serial0IoPortBase
    = 0x00000000000002e8 (744)
    00:00:03.244 Serial0Irq
    = 0x0000000000000003 (3)
    00:00:03.244 Serial1IoPortBase
    = 0x00000000000002f8 (760)
    00:00:03.244 Serial1Irq
    00:00:03.244 ShowCpu
    00:00:03.244 ShowRtc
    00:00:03.244 SmcEnabled
    00:00:03.244
    00:00:03.244 [/Devices/acpi/0/LUN#0/] (level 4)
    00:00:03.244 Driver = "ACPIHost" (cb=9)
    00:00:03.244
    00:00:03.244 [/Devices/acpi/0/LUN#0/Config/] (level 5)
    00:00:03.244
    00:00:03.245 [/Devices/ahci/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/ahci/0/] (level 3)
    00:00:03.245 PCIBusNo = 0x0000000000000000 (0)
    00:00:03.245 PCIDeviceNo
    = 0x000000000000000d (13)
    00:00:03.245 PCIFunctionNo
    00:00:03.245 Trusted
    00:00:03.245
    00:00:03.245 [/Devices/ahci/0/Config/] (level 4)
    00:00:03.245 Bootable
    00:00:03.245 PortCount
    00:00:03.245 PrimaryMaster
    00:00:03.245 PrimarySlave
    00:00:03.245 SecondaryMaster
    = 0x0000000000000002 (2)
    00:00:03.245 SecondarySlave
    00:00:03.245
    00:00:03.245 [/Devices/ahci/0/LUN#999/] (level 4)
    00:00:03.245 Driver = "MainStatus" (cb=11)
    00:00:03.245
    00:00:03.245 [/Devices/ahci/0/LUN#999/Config/] (level 5)
    00:00:03.245 DeviceInstance
    = "ahci/0" (cb=7)
    00:00:03.245 First = 0x0000000000000000 (0)
    00:00:03.245 Last
    00:00:03.245 pConsole
    = 0x0000000002113178 (34 681 208)
    00:00:03.245 papLeds
    = 0x0000000002113390 (34 681 744)
    00:00:03.245 pmapMediumAttachments
    = 0x0000000002113494 (34 682 004)
    00:00:03.245
    00:00:03.245 [/Devices/apic/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/apic/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/apic/0/Config/] (level 4)
    00:00:03.245 IOAPIC
    00:00:03.245 NumCPUs
    00:00:03.245
    00:00:03.245 [/Devices/e1000/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/e1000/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/e1000/0/Config/] (level 4)
    00:00:03.245 AdapterType
    00:00:03.245 CableConnected
    00:00:03.245 LineSpeed
    00:00:03.245 MAC = "08 00 27 3c 31 98" (cb=6)
    00:00:03.245
    00:00:03.245 [/Devices/e1000/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "NAT" (cb=4)
    00:00:03.245
    00:00:03.245 [/Devices/e1000/0/LUN#0/Config/] (level 5)
    00:00:03.245 AliasMode = 0x0000000000000000 (0)
    00:00:03.245 BootFile = "IE11 - Win7.pxe" (cb=16)
    00:00:03.245 DNSProxy = 0x0000000000000000 (0)
    00:00:03.245 Network = "10.0.2.0/24" (cb=12)
    00:00:03.245 PassDomain = 0x0000000000000001 (1)
    00:00:03.245 TFTPPrefix = "C:UsersMyUserName/.VirtualBoxTFTP" (cb=33)
    00:00:03.245 UseHostResolver = 0x0000000000000000 (0)
    00:00:03.245
    00:00:03.245 [/Devices/e1000/0/LUN#999/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/e1000/0/LUN#999/Config/] (level 5)
    00:00:03.245 Last
    = 0x0000000002113468 (34 681 960)
    00:00:03.245
    00:00:03.245 [/Devices/hda/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/hda/0/] (level 3)
    = 0x0000000000000005 (5)
    00:00:03.245
    00:00:03.245 [/Devices/hda/0/Config/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/hda/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "AUDIO" (cb=6)
    00:00:03.245
    00:00:03.245 [/Devices/hda/0/LUN#0/Config/] (level 5)
    00:00:03.245 AudioDriver
    = "dsound" (cb=7)
    00:00:03.245 StreamName
    00:00:03.245
    00:00:03.245 [/Devices/i8254/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/i8254/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/i8254/0/Config/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/i8259/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/i8259/0/] (level 3)
    00:00:03.245 Trusted = 0x0000000000000001 (1)
    00:00:03.245
    00:00:03.245 [/Devices/i8259/0/Config/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/mc146818/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/mc146818/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/mc146818/0/Config/] (level 4)
    00:00:03.245 UseUTC
    00:00:03.245
    00:00:03.245 [/Devices/parallel/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/pcarch/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/pcarch/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/pcarch/0/Config/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/pcbios/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/pcbios/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/pcbios/0/Config/] (level 4)
    00:00:03.245 BootDevice0 = "FLOPPY" (cb=7)
    00:00:03.245 BootDevice1
    = "DVD" (cb=4)
    00:00:03.245 BootDevice2
    = "IDE" (cb=4)
    00:00:03.245 BootDevice3
    = "NONE" (cb=5)
    00:00:03.245 FloppyDevice
    = "i82078" (cb=7)
    00:00:03.245 HardDiskDevice
    = "piix3ide" (cb=9)
    00:00:03.245 IOAPIC = 0x0000000000000000 (0)
    00:00:03.245 McfgBase
    00:00:03.245 McfgLength
    00:00:03.245 PXEDebug
    00:00:03.245 RamHoleSize
    00:00:03.245 RamSize
    00:00:03.245 SataHardDiskDevice = "ahci" (cb=5)
    00:00:03.245 SataPrimaryMasterLUN = 0x0000000000000000 (0)
    00:00:03.245 SataPrimarySlaveLUN
    00:00:03.245 SataSecondaryMasterLUN
    00:00:03.245 SataSecondarySlaveLUN
    00:00:03.245 UUID = "78 6a 23 13 fd ae 1f 43 b7 45 74 60 21 90 0c c0" (cb=16)
    00:00:03.245
    00:00:03.245 [/Devices/pcbios/0/Config/NetBoot/] (level 5)
    00:00:03.245
    00:00:03.245 [/Devices/pcbios/0/Config/NetBoot/0/] (level 6)
    00:00:03.245 NIC = 0x0000000000000000 (0)
    00:00:03.245
    00:00:03.245 [/Devices/pci/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/pci/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/pci/0/Config/] (level 4)
    00:00:03.245 IOAPIC
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/Config/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "KeyboardQueue" (cb=14)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#0/AttachedDriver/] (level 5)
    00:00:03.245 Driver
    = "MainKeyboard" (cb=13)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#0/AttachedDriver/Config/] (level 6)
    00:00:03.245 Object = 0x00000000020b9398 (34 313 112)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#0/Config/] (level 5)
    00:00:03.245 QueueSize
    = 0x0000000000000040 (64)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#1/] (level 4)
    00:00:03.245 Driver = "MouseQueue" (cb=11)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#1/AttachedDriver/] (level 5)
    00:00:03.245 Driver
    = "MainMouse" (cb=10)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#1/AttachedDriver/Config/] (level 6)
    00:00:03.245 Object = 0x000000000209dd00 (34 200 832)
    00:00:03.245
    00:00:03.245 [/Devices/pckbd/0/LUN#1/Config/] (level 5)
    = 0x0000000000000080 (128)
    00:00:03.245
    00:00:03.245 [/Devices/pcnet/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/Config/] (level 4)
    00:00:03.245 Type = "PIIX4" (cb=6)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/Config/PrimaryMaster/] (level 5)
    00:00:03.245 NonRotationalMedium = 0x0000000000000000 (0)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/Config/SecondaryMaster/] (level 5)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "Block" (cb=6)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#0/AttachedDriver/] (level 5)
    00:00:03.245 Driver
    = "VD" (cb=3)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#0/AttachedDriver/Config/] (level 6)
    00:00:03.245 Format
    = "VMDK" (cb=5)
    00:00:03.245 Path
    = "C:UsersMyUserNameVirtualBox VMsIE11 - Win7Snapshots/{eaddf2cb-36c5-4ff7-b148-487b1613dc92}.vmdk" (cb=97)
    00:00:03.245 Type
    = "HardDisk" (cb=9)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#0/AttachedDriver/Config/Parent/] (level 7)
    00:00:03.245 Format
    = "VMDK" (cb=5)
    00:00:03.245 Path
    = "C:UsersMyUserNameVirtualBox VMsIE11 - Win7IE11 - Win7-disk1_1.vmdk" (cb=68)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#0/Config/] (level 5)
    00:00:03.245 Mountable = 0x0000000000000000 (0)
    00:00:03.245 Type = "HardDisk" (cb=9)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#2/] (level 4)
    00:00:03.245 Driver
    = "Block" (cb=6)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#2/Config/] (level 5)
    00:00:03.245 Mountable = 0x0000000000000001 (1)
    00:00:03.245 Type = "DVD" (cb=4)
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#999/] (level 4)
    00:00:03.245 Driver
    00:00:03.245
    00:00:03.245 [/Devices/piix3ide/0/LUN#999/Config/] (level 5)
    = "piix3ide/0" (cb=11)
    00:00:03.245 Last
    = 0x0000000002113380 (34 681 728)
    00:00:03.245
    00:00:03.245 [/Devices/serial/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/serial/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/serial/0/Config/] (level 4)
    00:00:03.245 IOBase
    00:00:03.245 IRQ
    00:00:03.245
    00:00:03.245 [/Devices/serial/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "Char" (cb=5)
    00:00:03.245
    00:00:03.245 [/Devices/serial/0/LUN#0/AttachedDriver/] (level 5)
    00:00:03.245 Driver
    = "NamedPipe" (cb=10)
    00:00:03.245
    00:00:03.245 [/Devices/serial/0/LUN#0/AttachedDriver/Config/] (level 6)
    00:00:03.245 IsServer = 0x0000000000000001 (1)
    00:00:03.245 Location = "\.pipedebug-com4" (cb=20)
    00:00:03.245
    00:00:03.245 [/Devices/serial/1/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/serial/1/Config/] (level 4)
    00:00:03.245 IOBase = 0x00000000000002f8 (760)
    00:00:03.245 IRQ
    00:00:03.245
    00:00:03.245 [/Devices/serial/1/LUN#0/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/serial/1/LUN#0/AttachedDriver/] (level 5)
    00:00:03.245 Driver
    00:00:03.245
    00:00:03.245 [/Devices/serial/1/LUN#0/AttachedDriver/Config/] (level 6)
    00:00:03.245 Location = "\.pipedebug-com2" (cb=20)
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/0/] (level 3)
    = 0x0000000000000006 (6)
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/0/Config/] (level 4)
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "VUSBRootHub" (cb=12)
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/0/LUN#0/Config/] (level 5)
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/0/LUN#999/] (level 4)
    00:00:03.245 Driver
    00:00:03.245
    00:00:03.245 [/Devices/usb-ohci/0/LUN#999/Config/] (level 5)
    00:00:03.245 Last
    = 0x000000000211348c (34 681 996)
    00:00:03.245
    00:00:03.245 [/Devices/vga/] (level 2)
    00:00:03.245
    00:00:03.245 [/Devices/vga/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/Devices/vga/0/Config/] (level 4)
    00:00:03.245 CustomVideoModes
    00:00:03.245 FadeIn
    00:00:03.245 FadeOut
    00:00:03.245 HeightReduction
    00:00:03.245 LogoFile = "" (cb=1)
    00:00:03.245 LogoTime = 0x0000000000000000 (0)
    00:00:03.245 MonitorCount
    00:00:03.245 ShowBootMenu
    00:00:03.245 VRamSize
    = 0x0000000001b00000 (28 311 552, 27 MB)
    00:00:03.245
    00:00:03.245 [/Devices/vga/0/LUN#0/] (level 4)
    00:00:03.245 Driver = "MainDisplay" (cb=12)
    00:00:03.245
    00:00:03.245 [/Devices/vga/0/LUN#0/Config/] (level 5)
    00:00:03.245 Object = 0x00000000020c36e0 (34 354 912)
    00:00:03.245
    00:00:03.245 [/Devices/virtio-net/] (level 2)
    00:00:03.245
    00:00:03.245 [/HWVirtExt/] (level 1)
    00:00:03.245 64bitEnabled
    00:00:03.245 EnableLargePages
    00:00:03.245 EnableNestedPaging
    00:00:03.245 EnableVPID
    00:00:03.245 Enabled
    00:00:03.245 Exclusive
    00:00:03.245
    00:00:03.245 [/MM/] (level 1)
    00:00:03.245 CanUseLargerHeap
    00:00:03.245
    00:00:03.245 [/PDM/] (level 1)
    00:00:03.245
    00:00:03.245 [/PDM/AsyncCompletion/] (level 2)
    00:00:03.245
    00:00:03.245 [/PDM/AsyncCompletion/File/] (level 3)
    00:00:03.245
    00:00:03.245 [/PDM/AsyncCompletion/File/BwGroups/] (level 4)
    00:00:03.245
    00:00:03.245 [/PDM/BlkCache/] (level 2)
    00:00:03.245 CacheSize
    = 0x0000000000500000 (5 242 880, 5 MB)
    00:00:03.245
    00:00:03.245 [/PDM/Devices/] (level 2)
    00:00:03.245
    00:00:03.245 [/PDM/Devices/VirtualKD/] (level 3)
    00:00:03.245 Path = "C:/Users/MyUserName/Downloads/VirtualKD-2.8/VBoxKD.dll" (cb=51)
    00:00:03.245
    00:00:03.245 [/PDM/Drivers/] (level 2)
    00:00:03.245
    00:00:03.245 [/PDM/Drivers/VBoxC/] (level 3)
    00:00:03.245 Path
    = "VBoxC" (cb=6)
    00:00:03.245
    00:00:03.245 [/TM/] (level 1)
    00:00:03.245 UTCOffset = 0x0000000000000000 (0)
    00:00:03.245
    00:00:03.245 [/USB/] (level 1)
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/] (level 2)
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/0/] (level 3)
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/0/Config/] (level 4)
    00:00:03.245 Absolute
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/0/LUN#0/] (level 4)
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/0/LUN#0/AttachedDriver/] (level 5)
    00:00:03.245 Driver
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/0/LUN#0/AttachedDriver/Config/] (level 6)
    00:00:03.245
    00:00:03.245 [/USB/HidMouse/0/LUN#0/Config/] (level 5)
    00:00:03.245
    00:00:03.245 [/USB/USBProxy/] (level 2)
    00:00:03.245
    00:00:03.245 [/USB/USBProxy/GlobalConfig/] (level 3)
    00:00:03.245
    00:00:03.245 ********************* End of CFGM dump **********************
    00:00:03.246 MM: cbHyperHeap=0x140000 (1310720)
    00:00:03.249 Host paging mode: PAE+PGE
    00:00:03.249 PGMPool: cMaxPages=288 (u64MaxPages=288)
    00:00:03.249 pgmR3PoolInit: cMaxPages=0x120 cMaxUsers=0x240 cMaxPhysExts=0x240 fCacheEnable=true
    00:00:03.251 REM: VBoxREM32
    00:00:03.269 TM: GIP - u32Mode=1 (SyncTSC) u32UpdateHz=100
    00:00:03.301 TM: cTSCTicksPerSecond=0x9e816674 (2 659 280 500) fTSCVirtualized=true fTSCUseRealTSC=false
    00:00:03.301 TM: fMaybeUseOffsettedHostTSC=true TSCTiedToExecution=false TSCNotTiedToHalt=false
    00:00:03.303 CoreCode: R3=00f10000 R0=85a51000 RC=a038a000 Phys=00000000bf251000 cb=0x2000
    00:00:03.309 AIOMgr: Default manager type is "Async"
    00:00:03.309 AIOMgr: Default file backend is "NonBuffered"
    00:00:03.309 BlkCache: Cache successfully initialised. Cache size is 5242880 bytes
    00:00:03.309 BlkCache: Cache commit interval is 10000 ms
    00:00:03.309 BlkCache: Cache commit threshold is 2621440 bytes
    00:00:03.315 AssertLogRel D:tinderboxwin-4.1srcVBoxVMMVMMR3PDMDevice.cpp(665) pdmR3DevReg_Register: (pReg->fFlags & PDM_DEVREG_FLAGS_GUEST_BITS_MASK) == PDM_DEVREG_FLAGS_GUEST_BITS_DEFAULT
    00:00:03.315 PDM: Rejected device 'VirtualKD' because it didn't match the guest bits.
    00:00:03.316 VMSetError: D:tinderboxwin-4.1srcVBoxVMMVMMR3VM.cpp(362) VMR3Create; rc=VERR_PDM_INVALID_DEVICE_GUEST_BITS
    00:00:03.316 VMSetError: Invalid host bit mask.
    00:00:03.317 ERROR [COM]: aRC=E_FAIL (0x80004005) aIID={1968b7d3-e3bf-4ceb-99e0-cb7c913317bb} aComponent={Console} aText={Invalid host bit mask. (VERR_PDM_INVALID_DEVICE_GUEST_BITS)}, preserve=false
    00:00:03.398 ERROR [COM]: aRC=E_ACCESSDENIED (0x80070005) aIID={1968b7d3-e3bf-4ceb-99e0-cb7c913317bb} aComponent={Console} aText={The virtual machine is not powered up}, preserve=false
    00:00:03.398 Power up failed (vrc=VERR_PDM_INVALID_DEVICE_GUEST_BITS, rc=E_FAIL (0X80004005))
