Value no longer displaying when floating over variable in debug
Sysprogs forums › Forums › VisualGDB › Value no longer displaying when floating over variable in debug
  • #11491
    jmkresse
    I have a project where the value of a variable is no longer being displayed when floating over it while in a debug session. What do I need to do to get that working again?
    Thanks in advance!
    #11494
    Please switch the GDB Session window to “All GDB interaction” and check if VisualGDB issues any gdb commands when you are trying to hover the mouse over a variable. If no, please check if this is broken for non-VisualGDB projects as well. If yes, please let us know if gdb reports any errors.
    #11545
    jmkresse
    The problem has disappeared. I had moved some of the source files around, and did a complete rebuild, so that may be why it disappeared. If it happens again, I will try your suggestions.
    Thanks!
