Hi, I’m using Visual GDB to do embedded firmware on an STM32 micro.
I’ve using Version 4.3 release 4 (VisualGDB-4.3r4-trial.msi).
In my project, I’ve created 2 user variables (MAJORVERSION and MINORVERSION) that contain the major and minor firmware version numbers of my project.
I’m passing these values to the source code via a “Preprocessor macro:
SWVER=”\”V$(MAJORVERSION).$(MINORVERSION)\””)
I can see this being passed to GCC in the Output window during the build process. I can also see that this value gets tranferred to “gcc_Release.h”, when makefile settings are altered. My source code correctly evaluates the SWVER macro correctly (SWVER = “xVy”) – and all is well!
However, if I change the value of the user variable (say MINORVERSION) via Visual GDB Project Properties and “Apply” the change, the gcc.Release.h file is not updated – even after a (re)Build. All I can do is to manually force the make file settings to be re-created and then the changes are passed across – but this is not ideal and I’ll forget!
Any ideas on what to do / how to solve this.
Thanks (in advance),
