Use Google Mock with VisualGDB?
Sysprogs forums › Forums › VisualGDB › Use Google Mock with VisualGDB?
  • #22267
    abritton
    I am evaluating VisualGDB with Visual Studio 2017, and am using Google Test for unit testing on a Linux platform.  My question is whether there is a way to use Google Mock with Google Test, and run the tests on the Linux target?  Thanks in advance.
    #22273
    Yes, please try installing VisualGDB 5.4 Preview 7 and get the latest version of the GoogleTest framework via the VisualGDB Package Manager. It does include GoogleMock.
    #22276
    abritton
    I am using VisualGDB 5.4 Preview 7 now, and can use Google Mock.  However, the Code Coverage feature no longer seems to be working.  I get the code coverage reports as expected, but the code coverage window does not show any functions.  The total %lines in %functions is displayed at the bottom of the window and nothing else.  Also, the highlight coverage source code is not highlighting anything.  What am I doing wrong?  This worked previously when I had the released version of VisualGDB installed.  I have attached a screenshot showing the blank code coverage window.  Thanks for your help in advance.
    #22278
    Thanks for reporting this. Looks like a bug of the preview build. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.4.7.2478.msi
    #22279
    abritton
    The code coverage window and highlighting works in this version.  Thank you so much for your extremely fast response.  Your customer support has been outstanding.
    #22282
    Good to know it works. Don’t hesitate to get back to us if you run into any further problems.
    #22387
    abritton
    Will the code coverage fix be included in the next preview?  Also, do you have an estimated release date for 5.4?
    Thank you.
    #22398
    Yes, the fix will be included. We currently plan to release another preview of v5.4 introducing a feature similar to CodeLens this week, then the first beta in another 1-2 weeks followed by a stable version in a few weeks more (depending on the feedback on Beta).
