Sysprogs forums › Forums › VisualGDB › Unable to run "Analyze Performance with VisualGDB"
- This topic has 1 reply, 2 voices, and was last updated 5 years ago by
March 12, 2021 at 01:30 #30154
mgandler
I am trying to run the tool “Analyze Performance with VisualGDB” on my target, but VisualGDB immediately aborts with the
following exceptions.
I tried to run valgrind on the device with the following code:
valgrind --tool=callgrind /tmp/CentralControllingApplicationit ran without issues and produced a log file.
Visual GDB Version 5.5R4
Exception details:
VisualGDB version: 5.5.104.3920
------------------ System.Exception ------------------
System.Exception: Valgrind failed to initialize. Please check the output log for details.
bei c9.h1(RemoteHostSettings f, String b, String e, String a, ModifiedEnvirionment d, d81 c)
bei lv1.p1.k.g_2(r a)
bei lv1.b()
bei lv1.z_2(DebugCustomizationSettings a, Boolean b)
bei nd1.t2()
bei df1.i1_2()
bei VisualGDB.GDBDebugEngine.s(gi a, n1 b)
trace=[c9.h1:280, lv1+p1+k.g_2:217, lv1.b:71, lv1.z_2:224, nd1.t2:9985, df1.i1_2:22, VisualGDB.GDBDebugEngine.s:58]Valgrind Diagnostics:
sh: xauth: not found
==1551== Callgrind, a call-graph generating cache profiler
==1551== Copyright (C) 2002-2017, and GNU GPL'd, by Josef Weidendorfer et al.
==1551== Using Valgrind-3.15.0 and LibVEX; rerun with -h for copyright info
==1551== Command: /tmp/CentralControllingApplication
==1551== Parent PID: 1465
==1551==
==1551== For interactive control, run 'callgrind_control --vgdb-prefix=/tmp/d11cecf7-32e9-4f2b-a21a-85935a794240 -h'.VisualGDB diagnostics
Launching Valgrind...
SSH [205]: executing command: valgrind --log-file="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/valgrind.log" --vgdb-prefix="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa" --tool=callgrind --callgrind-out-file="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/callgrind.out" --vgdb=yes --vgdb-error=0 /tmp/CentralControllingApplication
SSH [206]: executing command: cat "/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/valgrind.log"
Starting profiling report converter: C:\Program Files (x86)\Sysprogs\VisualGDB\valgrind2sprof64.exe - "C:\Users\..12_03_2021_10_15_57.sprofreport" "12.03.2021 10:15:57"
Valgrind reader process (attempt #0) exited with code 0, valgrind process is still running, report conversion started
Finished sending data to profiler report converter
Producing report (elapsed 0)
Elapsed: 0
Profiler report converter exited with code 0
SSH [207]: executing command: "rm" -rf "/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa"
SSH [207]: command exited with code 0 after 56 msec
SSH [205]: command exited with code 0 after 702 msec
SSH [206]: command exited with code 0 after 689 msecMarch 12, 2021 at 08:50 #30155support
The “Valgrind failed to initialize” error is shown when the diagnostics process (with the ‘cat’ command) would exit prematurely. Please try running the commands manually to reproduce the problem:
rm -rf /tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa mkdir /tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa mkdifo /tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/valgrind.log valgrind --log-file="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/valgrind.log" --vgdb-prefix="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa" --tool=callgrind --callgrind-out-file="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/callgrind.out" --vgdb=yes --vgdb-error=0 /tmp/CentralControllingApplication cat "/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa/valgrind.log" vgdb --vgdb-prefix="/tmp/26c17f45-e5f7-41fa-890b-15cdd7464eaa" --port=2000
Then, check for any suspicious messages or strange behavior. Note that the last 3 commands will need to run in parallel from 3 different terminal windows.
If none of the commands exits, please try checking if running gdb (gdb <executable>) and connecting it to Valgrind (target remote :2000 followed by continue) works.
Please let us know your findings and we will help you configure VisualGDB to work with your setup as well.
