Unable to install on XP
Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Unable to install on XP
  • #286
    On a XP box, I’ve installed the SDK and WDK (7600) and in the wizard it specifies to add the paths (either DDK or WDK). I add the WDK path but all the buttons button except for ‘Canceled’ or dimmed so that I cannot proceed with install. What am I doing wrong?
    Bernie
    #1699
    Do you put the complete path including the version number (e.g. E:WinDDK7600.16385.0)?
    If yes, could you please post a screenshot?
    #1700
    Same for me, all buttons are grayed out. Running WinDDK 7.1 on Windows 7 64bit
    #1701
    Same here. However, if you select the directory (in my case, C:WinDDK7600.16385.1) and then add then delete a trailing character, the next button displays fine.
    There is also another bug (hopefully only visual again) on the next page where it says “Visual Studio 2008 Add-ins location” instead of 2010 for the 3rd option.
    Cheers
