Sysprogs forums › Forums › VisualGDB › Unable to create a blink Arduino project
- This topic has 11 replies, 2 voices, and was last updated 6 years, 11 months ago by
October 5, 2019 at 06:27 #26040
Johanan
ParticipantI tried a few time to start a new Arduino project with different boards, but no joy.
Original Arduino IDE works OK.
VisualGDB is latest version.
See attached screen.
This is the output: ( one for STM32F103 board, one for Arduino Leonardo)
Checking if any source files need uploading…
Saved the code model to C:\Users\Johanan\Documents\Arduino\ArduinoProject3\VisualGDBCache\ArduinoProject3-Debug-Generic_STM32F103C_series\BuildCommandLines.txt
Failed to parse code model from C:\Users\Johanan\Documents\Arduino\ArduinoProject3\VisualGDBCache\ArduinoProject3-Debug-Generic_STM32F103C_series\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
at ix.h1.c_2(IEnumerable`1 a)
Compiler output:
Saved the code model to C:\Users\Johanan\Documents\Arduino\ArduinoProject4\VisualGDBCache\ArduinoProject4-Debug-Arduino_Leonardo\BuildCommandLines.txt
Failed to parse code model from C:\Users\Johanan\Documents\Arduino\ArduinoProject4\VisualGDBCache\ArduinoProject4-Debug-Arduino_Leonardo\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
Compiler output:Attachments:
You must be logged in to view attached files.October 5, 2019 at 21:34 #26047support
Please try this build: VisualGDB-5.5.1.3289.msi
Then open the main source file and check if VisualGDB suggests cleaning up redundant Arduino packages. If yes, please proceed with the cleanup.
If not, please try building the project and share the output from the View->Output->Build view (the screenshot you attached shows the output from VisualGDB Advanced Project Subsystem that is different).
October 6, 2019 at 17:29 #26048Johanan
ParticipantI did it and it suggested the cleanup, I clicked OK, and it cleaned up.
Then started a new project, same result. output from Build:
Command exited with code 1
Executable: C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino\arduino-builder.exe
Arguments: -compile -logger=machine -fqbn=stm32duino:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=DFUUploadMethod,cpu_speed=speed_72mhz,opt=osstd -build-path C:\MyWork\ArduinoProjects\ArduinoProject1\Output\Generic_STM32F103C_series\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Arduino/hardware” -hardware C:\Users\Johanan\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Arduino/tools-builder” -tools C:\Users\Johanan\AppData\Local/Arduino15/packages -built-in-libraries “C:\Program Files (x86)\Arduino/libraries” -libraries C:\Users\Johanan\Documents\Arduino\ -prefs=runtime.tools.stm32tools.path=C:\Users\Johanan\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2019.9.24 sketches/ArduinoProject1.ino
Directory: C:\MyWork\ArduinoProjects\ArduinoProject1
VisualGDB: Error: Command-line action failed
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========And the output from VisualGDB Advanced Project Subsystem is:
Saved the code model to C:\MyWork\ArduinoProjects\ArduinoProject1\VisualGDBCache\ArduinoProject1-Debug-Generic_STM32F103C_series\BuildCommandLines.txt
Failed to parse code model from C:\MyWork\ArduinoProjects\ArduinoProject1\VisualGDBCache\ArduinoProject1-Debug-Generic_STM32F103C_series\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
at ov1.j1.m_2(IEnumerable`1 a)
Compiler output:
Saved the code model to C:\MyWork\ArduinoProjects\ArduinoProject2\VisualGDBCache\ArduinoProject2-Debug-Arduino_Leonardo\BuildCommandLines.txt
Failed to parse code model from C:\MyWork\ArduinoProjects\ArduinoProject2\VisualGDBCache\ArduinoProject2-Debug-Arduino_Leonardo\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
Compiler output:
Loading cached code model from C:\MyWork\ArduinoProjects\ArduinoProject1\VisualGDBCache\ArduinoProject1-Debug-Generic_STM32F103C_series\BuildCommandLines.txt…
Compiler output:
Checking for file modifications…
Found changed files since last query (see C:\MyWork\ArduinoProjects\ArduinoProject1\VisualGDBCache\ArduinoProject1-Debug-Generic_STM32F103C_series\BuildFileStats.txt.old vs C:\MyWork\ArduinoProjects\ArduinoProject1\VisualGDBCache\ArduinoProject1-Debug-Generic_STM32F103C_series\BuildFileStats.txt.new). Rerunning code model query..
Compiler output:Hope this gives a clue.
BTW I do have it on my laptop, with much fewer Arduino broads installed, but on the laptop it looks OK at first glance – I did not play too much with it.
Regards
October 6, 2019 at 17:40 #26049support
KeymasterPlease check the part of the build log before the “Command exited with code 1” line. It should show the actual error message coming from the arduino-builder tool.
October 6, 2019 at 18:30 #26050Johanan
ParticipantHere it is:
—— Build started: Project: ArduinoProject1, Configuration: Debug Generic_STM32F103C_series ——
Launching Arduino builder…
VisualGDB: Run “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino\arduino-builder.exe -compile -logger=machine -fqbn=stm32duino:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=DFUUploadMethod,cpu_speed=speed_72mhz,opt=osstd -build-path C:\MyWork\ArduinoProjects\ArduinoProject1\Output\Generic_STM32F103C_series\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Arduino/hardware” -hardware C:\Users\Johanan\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Arduino/tools-builder” -tools C:\Users\Johanan\AppData\Local/Arduino15/packages -built-in-libraries “C:\Program Files (x86)\Arduino/libraries” -libraries C:\Users\Johanan\Documents\Arduino\ -prefs=runtime.tools.stm32tools.path=C:\Users\Johanan\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2019.9.24 sketches/ArduinoProject1.ino” in directory “C:\MyWork\ArduinoProjects\ArduinoProject1” on local computer
error: ctags pattern is missingOctober 7, 2019 at 04:24 #26056support
KeymasterStrange. Normally the arduino builder should have displayed more details.
Either way, please try deleting/moving out the C:\Users\Johanan\AppData\Local/Arduino15 folder and then create another Arduino project for that target. This will force VisualGDB to re-install all the libraries and resolve any inconsistencies that could have been left by the previous setup.
October 7, 2019 at 18:23 #26066Johanan
ParticipantI did,
It really downloaded again all the libraries, but the problem is stubborn. It is the same.
In another post I have strange issues with simple STM32L05 device. Should I Uninstall VisualGDB, clean up and re-install it?
if Yes, please specify which directories should be deleted after uninstall, in order to leave no traces so I can make a very fresh install.
October 8, 2019 at 01:54 #26081support
KeymasterSorry, we have tried reproducing the issue on a clean machine, but could not get anything to fail
The problem might be caused by a conflict with some other package versions installed somewhere else (see the directories listed in the build command line, such as C:\Program Files (x86)\Arduino/hardware).
Please try the following steps to resolve this:
- Try clearing the Tools->VisualGDB->Arduino->Arduino IDE Directory setting.
- Try clearing any other directories mentioned in the build command line.
- Confirm that the problem exists for a freshly created demo project and is not specific to one pre-existing project, that could be referencing some libraries incorrectly.
If nothing helps, please try running the build from the Arduino IDE under Process Monitor and enable filters for “Process Create” event. It will show the command line used by the Arduino IDE to launch arduino-builder (you would need to locate the instance that has -compile among the arguments). The differences in the build results are likely triggered by the differences in command lines (e.g. the Arduino IDE passes some paths in a different order).
Please try comparing the command lines and then adjusting the VisualGDB’s command line to match the one captured from Arduino IDE and running it manually via Command Prompt. If you can find a specific argument, or argument sequence that triggers the problem, we should be able to update VisualGDB to avoid it and produce the same results as Arduino IDE does.
October 8, 2019 at 11:36 #26085Johanan
ParticipantWe are making progress.
If I clear the Arduino IDE directory ( 1.jpg), it compiles and run, but I am unable to see debugged source code. ( it does not download anything).
The break point is off (2.jpg) and it shows (3.jpg).
Using bluePill stm32F103C8, and STlink-V2
If I set the Arduino IDE directory to the correct value (C:\Program Files (x86)\Arduino) it make no difference.
Regards.
Johanan
You must be logged in to view attached files.October 8, 2019 at 21:03 #26112support
KeymasterThanks, it looks like the new STM32 Arduino package builds executables without debug information by default.
We have updated VisualGDB to automatically detect and fix this condition: VisualGDB-5.5.1.3298.msi (see the bar on top of the source files belonging to the Arduino project).
October 9, 2019 at 07:28 #26123Johanan
ParticipantNow this looks OK.
Only thing that may be a concern to you is that when I set the Arduino IDE directory to correct path, then the project is not built correctly.
If I leave this setting empty, all is OK (and nothing is downloaded).
Regards
October 10, 2019 at 05:46 #26129support
KeymasterGood to know it works.
Regarding the Arduino IDE, it looks like some sort of a conflict between different versions of the packages in the Arduino directory and the VisualGDB directory. We should be able to fix this if you could archive the entire Arduino IDE directory and also the C:\Users\Johanan\AppData\Local/Arduino15 directory so that we could reproduce everything on our side. But since the current workaround fixes the problem, you can simply proceed with having the Arduino IDE directory unspecified.
