Sysprogs forums › Forums › VisualGDB › two question for visualgdb
- This topic has 4 replies, 2 voices, and was last updated 11 years, 7 months ago by
ronaldinho.
August 20, 2014 at 02:33 #889
ronaldinho
Participantsoory for my poor english:
1 i am use a compute which ssh port is not on 22,i hope i can sepercific the port
2 in the ssh host manage i connect to a machine ,it auth pass ,but alwayse wait on the configure,why? it uname -a return was not common string ,dose it have something with it?August 21, 2014 at 01:33 #3345support
Yes, you can override the SSH port by specifying host:port in the “host name” field.
During “configuring” stage VisualGDB adds your public key to ~/.ssh/authorized_keys. If it hangs in this stage, please check whether the file is writable.
You can also disable the “setup public key authentication” and use the password instead.August 22, 2014 at 13:22 #3344ronaldinho
Participant@bazis wrote:
You can also disable the “setup public key authentication” and use the password instead.oh 3ku very much 🙂 ,I will try it .
August 25, 2014 at 05:12 #3347ronaldinho
You can also disable the “setup public key authentication” and use the password instead.hello ,now i found another problem, i cancel check the “setup public key authentication” ,and it doesn’t blocked, but when the dialog closed, the whole vs2012 does not respond. i have to close it forcibly.
i guess it was checking the toolchain, when i create a new project ,in “linux coputer selcection” step ,i selete create a new ssh comnection, normally ,it wil check the tool chain and go to the “source code access” step , but when i specifies the computer it also lead to the whole vs2012 none-respoding.
the computer i specified is a “compile environment” that i connect it with ssh it will chroot to a directory separated from other users.
dose it have something wrong with visualgdb or can you help me with it ?September 2, 2014 at 03:05 #3346support
Chroot can be a problem here. Public key authentication setup requires access to
/.ssh and if it becomes unavailable as a result of the chroot call, VisualGDB cannot physically do the setup.
You can do the setup manually by running VisualGDB.exe /dumpsshkey:file.txt and then appending the contents of file.txt to/.ssh/authorized_keys on the remote machine. -
