Sysprogs forums › Forums › WinCDEmu › The virtual disk undeletable & system shut-down failure…
- This topic has 12 replies, 3 voices, and was last updated 13 years, 12 months ago by
Anonymous.
August 8, 2011 at 13:18 #337
aq12
ParticipantDear Administrator:
Hi. I just installed ver. 3.6 to try, but I found a strange problem. After I press “Eject” to unmountt my virtual disk J:, the file management software “Total Commander” does not show J: disk anymore as your design, but J: disk unfortunately is still appearing in “Computer” forder as the following screenshots I made:
I couldn’t remove J: disk away from “Computer” forder. What’s going on? Would you please kindly help to fix this bug! Thanks a lot!
P.S. I’m using Windows XP SP3
August 9, 2011 at 07:48 #1925support
KeymasterWas there an error message when you clicked “unmount”?
What happens when if you double-click at the drive icon in Explorer? Does the drive open, or is there an error?
Is the CDROM still visible in Device Manager?August 9, 2011 at 14:04 #1926aq12
Is the CDROM still visible in Device Manager?I didn’t have no error message when I clicked “unmount”.
Jumping out Windows Media Player with empty screen when I double-click at the drive icon in Explorer.
I didn’t check Device Manager, sorry.
I found this problem occurred after I used KMPlayer to see the movie in ISO file type. I have to reboot my computer to let “Computer” forder forget the virtual disk.
August 9, 2011 at 14:24 #1927support
KeymasterDoes it happen always? Or did it happen only one time?
August 9, 2011 at 14:26 #1928aq12
(I edited my last reply, please check it again)
August 9, 2011 at 14:54 #1929aq12
ParticipantOh, too bad! I found not only couldn’t clean the virture disk out of Computer folder but also made my computer failed to shut-down (system locked during shut-down procedure) after I used KMPlayer to see the move in ISO file type mounted by WinCDEmu. Quite a big trouble!
August 9, 2011 at 15:06 #1930support
KeymasterMaybe, it’s a bug in KMPlayer? WinCDEmu does not lock the system. Anyway, I’ll check for compatibility with KMPlayer and see what I can do.
August 13, 2011 at 04:46 #1931aq12
ParticipantI tried “Virtual CloneDrive” and no these problems at all because “Virtual CloneDrive” does not allow to unmount virtual disk. Therefore, I think unmounting virtual disk is the reason made my system shut-down failure. I suggest you shoud find the bug out from the unmounting procedure. Some system parameters must be ignored.
August 14, 2011 at 16:20 #1932support
KeymasterIt seems to be a bug of KMPlayer. Please install the latest KMPlayer version.
August 17, 2011 at 03:53 #1933aq12
ParticipantI’m using KMPlayer 3.0.0.1440. The newest version is KMPlayer 3.0.0.1441. Ok, I’ll try it. Hope you are right even I have no confidence. Anyway, thanks for your kind reply!
August 17, 2011 at 07:36 #1934aq12
ParticipantHi. I just tried The newest version KMPlayer 3.0.0.1441. Unfortunately, still same problems I got. Hope your next version can solve these problems. Many thanks!
August 22, 2011 at 12:26 #1935aq12
ParticipantI tried UltraISO PE 9.3.2.2276 to built a virtural disk. No problem at all. I’m quite sure the problems caused by WinCDEmu’s unmounting. As we know, the system does not allow hot unpluging out any disk driver, does it? Unmount virtual disk means hot unpluging out the disk driver so the system is serching and trying to close the disk while shut down computer I suppose.
April 6, 2012 at 12:40 #1936Anonymous
ParticipantHI,
i have the same problem here. Playing a movie from a mounted DVD-ISO with MediaPlayerClassic or even Windows Media Player lets WinCDEmu stopp working. You cannot dismount the ISO completely. The Imagename disappears after the drive letter. The drive cannot be opened againg in explorer.
System-Shutdown hangs. Even mounting another ISO does not work anymore.
Using VLC-Media-Player this problem does not occur! But VLC-Media Player does not play all my ISOs. That’s why I prefer MediaPlayer Classic.Can you please solve the problem?
Kind regards
Ewald -
