Test Container not building on Jenkins
Sysprogs forums › Forums › VisualGDB › Test Container not building on Jenkins
  • #27268
    Roman.Thiel
    Today i am trying to get an embedded unit test running on Jenkins using the tiny embedded test engine. So good so far i got it running if i check-in the testcontainer into the source control.
    It seens that the testcontainer is not build automaticly. It can be reproduced like this:
    1. Open Visual Studio
    2. Use “Clean” on Unit Test project
    3. Use “Build” on Unit Test project -> “\VisualGDB\VisualGDBCache\xxx-Release” folder only contains “MemoryUtilizationReport.xml”
    4. Now use “Run Tests” on projects -> vgdbtestcontainer is created
    I am using VisualGDB-5.5.3.3462 because of the test result publish isues. My Visual Studio Version is 16.3.10
    Is there a way to force a build of the vgdbtestcontainer?
    Roman
    #27271
    Yes, please use the following setting: VS Project Properties -> General -> General -> Generate a test container file = Yes.
    Note that this setting is stored separately for Debug/Release configurations, hence you need to update it for every relevant configuration.
    #27284
    Roman.Thiel
    Thank you. That helped me.
    Roman
