Suspected Project Import Problem or Compiler problem
Sysprogs forums Forums VisualGDB Suspected Project Import Problem or Compiler problem
Viewing 15 posts - 1 through 15 (of 39 total)
  • #23307
    Miao Mico
    My project is based on Keil v5.
    I import it into vs&visual gdb , but it can’t compile succeed .
    But it can work via Keil compiler .
    VGDB will show this error .
    But i can use the vs->right-click menu->go to definition to find it .
    I am very confused , please .
    #23310
    Miao Mico
    ADD INFO.
    My project is based on Standard Peripherals Library.
    #23319
    Most likely, your project does not enable the CRYP module in the configuration file. Please try searching for CRYP (case-sensitive, whole word) in the ST peripheral library folders. Most likely you will find a definition #ifdef-ed with a macro like STM32_CRYP_ENABLED. Then check your configuration file (typically stm32_*_config.h in the project directory) for similar definitions and uncomment/add the definition enabling the CRYP module.
    #23322
    Miao Mico
    But why keil can use the project correctly ?
    It won’t show error message like vs&vGDB .
    #23324
    Most likely the Keil project is using a different configuration file.
    If you have 2 similar projects and would like to compare them, please consider enabling the preprocessor output in VisualGDB (VS Project Properties -> C/C++ -> Outputs) and Keil. This will expand all #include<> directives and the preprocessor macros, so you should be able to see where are various macros/variables defined and why the corresponding definition was not included in the other project.
    #23332
    Miao Mico
    I thought you said preprocesser was what VisualGDB Project Properties -> MSbuild setting -> Preprocessor Macros list.
    What Keil correspondes is Option -> C/C++ -> Proprocesser Symbol -> Define lists
    So , i think it should’t be that fault , the preprocessor .
    Because the VisualGDB project is inported from the keil .
    if the ViusualGDB is imported correctly ,it should be the same preprocesser list.
    And now it is the same .
    And i have tried what you said the last time.
    • This reply was modified 7 years, 2 months ago by Miao Mico.
    #23335
    Depending on the mode you used for importing the project, the preprocessor macros might not have been imported automatically.
    If you could attach your keil project file (no source files are necessary), the screenshots of all the steps of the VisualGDB import wizard and the macro name that is set in the Keil project and not automatically imported into VisualGDB, we should be able to tell what is going on and update our importer accordingly.
    #23381
    Miao Mico
    I’m so sorry about that.
    I can’t understand what you mean .
    I think the mode i used for importing my project is Automatically import a project in a different format -> Import an existing Keil Project -> Build using : Keil ARM Compiler -> My-Project-File.
    Is it right ?
    If not , please tell me again .
    Thanks.
    About the Keil project file .
    And i can consider and can provide the Keil Project file via email .
    And you can provide your e-mail address ?
    #23384
    Miao Mico
    Add the Keil project screenshot .
    #23390
    The importing settings look correct, so the macros should get imported properly. Please send your project file via our support form and we will check what is going on.
    #23436
    Miao Mico
    I have send the Test.uvprojx to support .
    Thanks .
    Waiting for your good news .
    #23443
    Thanks for the project file. We have rechecked the import and the macros got imported properly. If you believe some specific macro is not being imported, please let us know and attach the relevant screenshots.
    #23471
    Miao Mico
    Check my question again , please .
    And you can change the direction of thinking .
    Where will cause my problem ?
    And i succeed once through an the old version of VisualGDB .
    i can‘t remember which version and how to config .
    And the project succeed is missing .
    So blue .
    And your compiler is ARMCC or ARMCLANG ?
    I think yours is gcc .
    If I am wrong, please forgive me .
    #23472
    Unfortunately we are still not sure what you meant. The logic for importing the macros is the same for both compilers.
    If you are still trying to solve the original problem with the CRYP definition, please check the  stm32_*_config.h file as suggested earlier. Depending on your project configuration, you may need to enable the CRYP module on the Keil Packages page of VisualGDB Project Properties (available in the Custom edition or higher).
    If this is not what you are looking for, please let us know exactly the problem you are trying to solve.
    #23473
    Miao Mico
    Thanks !
    Let me comb train of thought .
