sometimes my code go to hard fault handler. I tried using real-time stack checking. I tried using from tutorial> https://visualgdb.com/tutorials/arm/stack/
Enabled in dynamic analysis and in framework enabled fast semihosting and fixed-size stack and heap.
Now debugging is dosnt start.
please help. thank you
exception details:
System.Exception: Could not find the following symbol in KIM:
_ZN29SysprogsInstrumentingProfiler22ReportFramesToProfilerEPKNS_17InstrumentedFrameEy
Please ensure that your project contains the embedded profiler framework and that you call the InitializeInstrumentingProfiler() function
at iq.c(String c, String d, k b, String a, e f, i e)
at bs1..ctor(String g, EmbeddedDynamicAnalysisSettings h, String d, l81 a, k b, lu1 f, EmbeddedRTOSProfile c, Dictionary2 e)
at ir.h()
at ir.k_2(DebugCustomizationSettings a)
at uu.w1()
at VisualGDB.GDBDebugEngine.x(tw1 a, i2 b)
You must be
