STemWin compiled Library
Sysprogs forums › Forums › VisualGDB › STemWin compiled Library
  • #799
    brettK
    Hi
    I am having trouble trying to include the STM32 ARM STemWIN grahics Library into the Visual Studio Project-GDB. It is a binary compiled library with a file name of “STemWin522_CM4_GCC.a”.
    Does anyone know how to do this?
    Brett
    #3097
    You can add the full path to the file to the “Additional linker inputs” field. Let us know if that works for you.
    #3096
    brettK
    Hi Thanks for the Info
    I did this and it compiles without error
    However the Library functions do not work.
    I i put a Breakpoint on the first function that i call from this Library. It will break, But it will not step into anything.
    Is there a way to set the Compiler to be C and not CPP only.?
    #3095
    Most likely your library was compiled without debugging symbols. You need to rebuild it yourself with debugging mode enabled (-ggdb) in order to be able to step into it.
    If you want to use Plain C, simply use files with .c extension, they will be compiled as C, not C++.
