I had a private ssh key with and I’m trying to setup the SSH connection, but getting the error that it can’t connect because a passphrase is required. I have put the passphrase into the passphrase dialog on the “Create New SSH connection” dialog. Since that repeatedly did not work, I removed the passphrase from the private key – and it still complains that it can’t connect because a passphrase is required.
Since the private key does NOT currently require a key, I’m not sure what the UI is complaining about…
Thanks.
