Sysprogs forums › Forums › VisualGDB › Split: Project load failed after update to 5.4 prev. 10
- This topic has 6 replies, 2 voices, and was last updated 6 years, 8 months ago by
July 3, 2019 at 13:46 #25237
SHA
ParticipantVisualGDB version: 5.4.10.<span style="color: #ff0000;">2582</span>
—————— Microsoft.Build.Exceptions.InvalidProjectFileException ——————
Microsoft.Build.Exceptions.InvalidProjectFileException: The attribute “ItemType” in element <ToolchainSettingsContainer> is unrecognized. C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\SysprogsPlatform.targetsHow to update my Visual GDB version without losing the key activation ?
<ul id=”iw-contextMenu6986″ class=”iw-contextMenu iw-created iw-cm-menu”>
<li class=”iw-has-submenu iw-mTrigger” title=””>Add to Phrasebook
<div class=”iw-cm-arrow-right”></div>
<ul id=”iw-contextMenu2051″ class=”iw-contextMenu iw-created iw-cm-menu”>
<li class=”iw-mDisable” title=””>No word lists for German -> Arabic…
<div class=”iw-mOverlay”></div>
<li class=”t-1″ title=””>Create a new word list…<li class=”t-1″ title=””>Copy
<ul id=”iw-contextMenu4189″ class=”iw-contextMenu iw-created iw-cm-menu”>
<ul id=”iw-contextMenu769″ class=”iw-contextMenu iw-created iw-cm-menu”>
<li class=”t-2″ title=””>Create a new word list…<li class=”t-2″ title=””>Copy
July 3, 2019 at 16:40 #25242support
KeymasterPlease let us know the email associated with your key (or update the forum profile accordingly) and we will let you know the latest VisualGDB version that can work with it.
July 4, 2019 at 07:55 #25246SHA
ParticipantI can’t change the email in the profile(the license is registered to private company), is that possible to sent you private message ?
In general, supposed the update process not affect the registration !
July 4, 2019 at 16:16 #25249support
KeymasterYes, please send it to us via our support form.
July 5, 2019 at 17:52 #25270support
KeymasterThanks for linking your license email to your forum email. According to our records, your license has an active maintenance period, so you can simply download and install the latest VisualGDB version from the download page and it will automatically pick up your existing license information.
July 25, 2019 at 13:18 #25451SHA
Participanthi Dears,
After update , i can’t run old programs
only new programs work fine ( cross complile linux qt)
July 25, 2019 at 15:50 #25454support
KeymasterPlease follow the instructions from our reply in the following thread: https://sysprogs.com/w/forums/topic/problem-error-building-after-update-to-new-release/
