Sysprogs forums › Forums › VisualGDB › Object reference not set to an instance of an object
- This topic has 5 replies, 2 voices, and was last updated 6 years ago by
September 29, 2020 at 08:38 #29131
hoterpone
ParticipantI’m also now occasionally getting a popup window that says “Warning: cannot perform inline build: Object reference not set to an instance of an object.” when trying to initiate a build. Restarting Visual Studio seems to make the build work normally again.
September 29, 2020 at 10:42 #29133support
KeymasterNo problem. Please try enabling diagnostic logging via View->Other Windows->VisualGDB Diagnostics Console. Then please try reproducing the problem and attach the full log from the diagnostics console here.
September 29, 2020 at 20:30 #29136hoterpone
ParticipantHere is the error from the diagnostics console:
inline build failed: —————— System.NullReferenceException ——————
at cq1.l4(TestFrameworkDefinition b, UnitTestTargetInfo a)
at un1..ctor(VisualGDBProjectSettings2 b, th c, IDELevelProjectInfoForBuilding a, sm d)
at y81.b(VisualGDBProjectSettings2 a, IDELevelProjectInfoForBuilding b)
at y81..ctor(VisualGDBProjectSettings2 a, IDELevelProjectInfoForBuilding c, sm b, Boolean d)
at i71..ctor(VisualGDBProjectSettings2 f, c b, IFormattedBuildLogLineSink e, BuildMode d, Int32 c, Boolean a)
at ln1.l(Byte[] a, ws1 b)
trace=[cq1.l4:1549, un1..ctor:13, y81.b:11, y81..ctor:72, i71..ctor:44, ln1.l:130]Let me know if you need everything else from the log, but it’s quite large from running all day long. Each attempt to rebuild in Visual Studio would produce another instance of the above messages. After restarting Visual Studio things seem to work properly again.
September 29, 2020 at 20:49 #29137support
KeymasterThanks for the log. Just to double-check, could you please confirm the build number from the Help->About VisualGDB window?
September 29, 2020 at 20:54 #29138hoterpone
ParticipantIt says “version 5.5 (build 3827)”. But like I said at https://sysprogs.com/w/forums/topic/build-errors-after-upgrading-to-visualgdb-5-5-preview-7/page/2/#post-29130, it’s not clear to me how I got this version – I thought that I had clicked on a link that said VisualGDB-5.5.8.3784.msi at https://sysprogs.com/w/forums/topic/build-errors-after-upgrading-to-visualgdb-5-5-preview-7/page/2/#post-28996 (though this link doesn’t seem to work any more).
This reply was modified 6 years ago by
hoterpone.
September 30, 2020 at 08:22 #29142support
KeymasterThanks for confirming this. It looked like an issue that was recently fixed, so we wanted to double-check that it is not caused by using an old build. We also moved this into a separate forum thread, as the issue appears different from the one discussed in the original thread.
Either way, this looks like the connection between VisualGDB and the floating license server gets lost, and the floating license state is not updated properly. If you could create a ticket for this via our support form, we can send you a private link to a special diagnostic build that should help narrow it down. Please do let us know what version of Visual Studio you are using so that we can double-check it on our side first.
