Smartty 3.1 no session tabs
Sysprogs forums Forums Other tools & products Smartty 3.1 no session tabs
  • #13329
    SOAS
    Using the latest V3.1 28 Nov 2017.
    I can open new sessions, but I cannot seem to have them tabbed, so unlike with the previous version I have one dashboard and multiple sessions with tabs, I now have multiple multiple sessions with tabs. With over 30 systems to look after, my desktop is too crowded. Or is the single dashboard gone now? Another issue is that I cannot  start a new session using an opened session, but via  Program File – Smartty – Select a Connection.
    #29656
    bkonia
    Same issue here. What’s the point of having a tabbed SSH client, if you have to open a separate window for each host?
    #29796
    larryw
    I know this is a bit late to the game, but this is working in version 3.2.
    #35045
    vajoe
    Using 3.3 on Windows 11.  No tabbed versions.  I get a window similar to the attached.  Then when I double it click a window similar to the second image.  Any ideas what is causing this?  I’ve tried reinstalling.
    Never mind, I see that tabs are only available for SSH sessions.  Serial, telnet, etc can’t be combined into the same tabbed window as SSH sessions.  Ugh.  Not what I wanted.
    • This reply was modified 2 years, 3 months ago by vajoe. Reason: Discovered the limitation
