SIGSEGV Segmentation Fault
Sysprogs forums › Forums › VisualGDB › SIGSEGV Segmentation Fault
  • #12332
    kd8
    I just purchased and installed VisualGDB to start developing linux application in VS2017.
    I have a solution setup to my Raspberry Pi 3 to work on a final project.  A simple “hello world” program causes VS to show a segmentation fault.  I attached a screenshot.
    I am not sure what to do about this.  Google and StackOverflow haven’t been much help.  I thought I would post here before pestering the developer.
    Thank you all in advance.
    [caption id="" align="alignnone" width="1366"]screen shot of VS2017 segmentation fault VS2017 SIGSEGV Segmentation Fault[/caption]
    #12333
    Most likely your toolchain is not compatible with the target system image.
    Please ensure you are using EXACTLY the same SD card image as listed for your toolchain on the toolchains page: http://gnutoolchains.com/raspberry/
    #12337
    kd8
    I have the version of Jessie installed, updated and ready.  I am starting a new solution and am unsure which to choose from the dropdown.
    #12339
    kd8
    I chose the default value.  It’s working.  Amazing!  Thank you kindly for your help.
    #12340
    No problem. Regarding the environment, we usually recommend choosing “fix value” if you are unsure. This works around the case where some PATH variables are applied for regular console sessions, but not for ‘command’ sessions used by VisualGDB to launch the debugger, leading to hard-to-trace “library not found” errors.
