Serial output is garbled
Sysprogs forums › Forums › VisualGDB › Serial output is garbled
  • #12797
    Yuex.S
    I use the esp8266, serial output has been garbled, do not understand is that you provide the SDK problem, or need to have any additional settings.
    #12799
    Most likely your baud rate in SmarTTY settings doesn’t match the baud rate of the device. Most ESP8266 boards have the default baud rate of 74880 and most USB-to-UART adapters have a default rate of 115200. Please try setting the baud rate manually.
    #12811
    Yuex.S
    Thanks very much, the baud rate and the program did not empty the flash cause.
