Resharper C++ compatibility guide
Sysprogs forums › Forums › VisualGDB › Resharper C++ compatibility guide
  • #7944
    Char
    I try last EAP of resharper ++  with VisualGDB.
    out of box smple project:
    unknown int types ambiguous  size_t, and some other problems on real project – STL issue and some others.
    1. First of all you need to change IntelliSense to VS from clang
    2. Create new header file for RS++ and add it to nmake forced includes (in project properties)
    My header file comtents
    #if defined(_MSC_VER)
    #define _GLIBCXX_ABI_TAG_CXX11
    #define __size_t__
    #if defined(__cplusplus)
    #undef __cplusplus
    #define __cplusplus 201402L
    #endif
    #ifndef __builtin_expect
    #define __builtin_expect(x,y) (x)
    #endif
    #ifndef __ASSERT_FUNCTION
    #define __ASSERT_FUNCTION
    #endif
    #ifndef __builtin_memset
    #define __builtin_memset(x,y)
    #endif
    #ifndef uint16_t
    typedef unsigned __int16 uint16_t;
    #endif //uint16_t
    #ifndef uint32_t
    typedef unsigned __int32 uint32_t;
    #endif //uint32_t
    #ifndef uint64_t
    typedef unsigned __int64 uint64_t;
    #endif //uint64_t
    #endif
    Voila:
    Voila
    #7947
    Thanks for sharing this!
