Remove debug symbols
Sysprogs forums › Forums › VisualGDB › Remove debug symbols
  • #35851
    lashmuelE
    I’m using VisualGDB version 5.6 in Visual Studio 2017
    How can i remove the debug symbols from build?
    In Win32 platform i select None in “C/C++->General->Debug information Format”. no such value in VisualGDB platform for this field.
    Also in Linker->Debugging->Generate Debug Info i also select the No option but no such field in VisualGDB
    Best regards
    Shmuel
    #35852
    bflannery
    I would probably just add a post build action for the release target to run “strip –strip-debug” on the produced executable.
    or
    You could pass “-Wl,–strip-debug” into the linker for your release target.
    #35853
    The VisualGDB setting for removing the debug info would be Linker->Advanced->Strip Debug Information. It enables the “-Wl,–strip-debug” option mentioned by @bflannery.
    But you can also add a post-build step for stripping it, moving it to a separate symbol file as shown here.
