Read-only .vgdbsettings files silently fail to update
Sysprogs forums Forums VisualGDB Read-only .vgdbsettings files silently fail to update
  • This topic has 1 reply, 2 voices, and was last updated 11 years ago by ket.
  • #845
    DanS
    We use a source control provider (Perforce) that makes files that are not checked out read-only. I checkin the .vgdbsettings files into source control, so normally they are read-only until I check them out.
    I noticed that if I forget to checkout a .vgdbsettings file and try and use the GUI to make a change, press OK will close the dialog and silently ignore the changes that were made. It seems like it should either produce a warning that the file couldn’t be updated or use Visual Studio’s API to try and checkout the file.
    I manually update my makefiles now, but before when I had VisualGDB update them for me, it seemed to have the same problem if the Makefile was read-only.
    #3219
    ket
    This problem has been reported before and a warning message was added in VisualGDB version 4.2.
