Raspberry Pi project – very slow deployment
Sysprogs forums › Forums › VisualGDB › Raspberry Pi project – very slow deployment
  • #29597
    nahumb
    I’m developing a Raspberry Pi project.
    After upgrading to the latest VGDB version (5.5R3 build 3898), project output deployment over SSH is very very slow (~28MB @ T > 5min).
    Ping time to the raspi is 1msec.
    PuTTY SSH session looks OK.
    Nahum.
    • This topic was modified 5 years, 10 months ago by nahumb.
    #29599
    SSH performance should not be affected by updating VisualGDB. Please try installing the previous version and check if the problem persists. If it does, please try deploying the same executable using a different SSH client (e.g. using PuTTY SCP or SmarTTY).
    If you can confirm that the problem only happens with VisualGDB, but not with other SCP software, we can help you narrow down the difference and make sure the VisualGDB performance matches the performance of other tools.
    #29600
    nahumb
    Thanks for the prompt reply.
    Following your suggestions, the problem was found to be a faulty ethernet switch I use for connecting my PC to several raspis I use.
    Nahum.
