QT 4.8.5 and BeagleBone Black problem
Sysprogs forums › Forums › VisualGDB › QT 4.8.5 and BeagleBone Black problem
  • #746
    Mantas
    I’ve set up everything as per tutorial up to step 15, but I have the following error when trying to compile:
    1>
    Build started: Project: QT, Configuration: Debug Win32
    1>  VisualGDB: Attempting inline build...
    1> VisualGDB: Executing prebuild actions
    1> VisualGDB: Run "C:SysGCCbeagleboneQtOtherqmake.exe QT.pro CONFIGNAME=Debug " in directory "F:BeagleBoneBlack_ProjectsQTQT" on local computer
    1> VisualGDB: Run "cmd.exe /c "C:SysGCCbeaglebonebinmake.exe"" in directory "F:BeagleBoneBlack_ProjectsQTQT" on local computer
    1> The syntax of the command is incorrect.
    1> make: *** [Debug/QT] Error 1
    1> 1> Command exited with code 2
    1> Executable: cmd.exe
    1> Arguments: /c "C:SysGCCbeaglebonebinmake.exe"
    1> Directory: F:BeagleBoneBlack_ProjectsQTQT
    1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0V120Microsoft.MakeFile.Targets(38,5): error MSB3073: The command ""C:Program Files (x86)SysprogsVisualGDBVisualGDB.exe" /build "F:BeagleBoneBlack_ProjectsQTQTQT.vcxproj" "/solution:F:BeagleBoneBlack_ProjectsQTQT.sln" "/config:Debug" "/platform:Win32"" exited with code 1.
    Build Summary 00:01.091 - Failed - Debug Win32 - QTQT.vcxproj
    Total build time: 00:03.638
    ========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped, Completed at 2014.01.17 11:41:31 ==========
    Best regards,
    Mantas
    #2969
    ket
    HI,
    Please check inside the Makefile in the project directory if there are any obvious issues with targets or recipes like non-existing path names.
    You can also run the make command with the -d argument to get a more thorough output from make. For this add the -d flag to make command arguments on the qmake project settings page in VisualGDB Project Properties. Then examine the log for any errors.
    #2970
    did you solve the problem?
    I have the same problem. but with a raspberry pi.
