Sysprogs forums › Forums › VisualGDB › Project Relocate
- This topic has 3 replies, 2 voices, and was last updated 9 years, 1 month ago by
February 14, 2017 at 14:16 #10413
Embedded_World
ParticipantHello,
i have nrf52dk.
i create the project on the Desktop.it build and worked perfectly.
when i move this project inside other folder then i got some error on build.
here is the error log
VisualGDB: Found 0 excluded file(s) for current configuration:
1> VisualGDB: No source changes detected. C:\Users\Test\Desktop\Projects\Ble_Advertising\Ble_Advertising\Makefile needs no updating.
1> VisualGDB: Run “cmd.exe /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug -j4″ in directory “C:\Users\Test\Desktop\Projects\Ble_Advertising\Ble_Advertising” on local computer
1> make: *** No rule to make target../../../AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.nordic.nrf5x/nRF5x/components/ble/common/ble_advdata.c', needed byDebug/ble_advdata.o’. Stop.
1> ————————————————————-
1> Command exited with code 2
1> Executable: cmd.exe
1> Arguments: /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug -j4
1> Directory: C:\Users\atif.shabbir\Desktop\Projects\Ble_Advertising\Ble_Advertising
1> Environment: LANG=en_US.UTF-8|PATH=C:\SysGCC\arm-eabi\bin;%PATH%|BSP_ROOT=C:\Users\Test\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nordic.nrf5x|TOOLCHAIN_ROOT=C:\SysGCC\arm-eabi|EFP_BASE=C:\Users\Test\AppData\Local\VisualGDB\EmbeddedEFPs|TESTFW_BASE=C:\Users\Test\AppData\Local\VisualGDB\TestFrameworks|BSP_ROOT=C:\Users\Test\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.nordic.nrf5x|TOOLCHAIN_ROOT=C:\SysGCC\arm-eabi|EFP_BASE=C:\Users\Test\AppData\Local\VisualGDB\EmbeddedEFPs|TESTFW_BASE=C:\Users\Test\AppData\Local\VisualGDB\TestFrameworks
1> 1>
1> 1>
1> 1>
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(46,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe” /rebuild “C:\Users\Test\Desktop\Projects\Ble_Advertising\Ble_Advertising\Ble_Advertising.vcxproj” “/solution:C:\Users\Test\Desktop\Projects\Ble_Advertising\Ble_Advertising.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
1> Done executing task “Exec” — FAILED.
1> 1>
1>Done building target “Rebuild” in project “Ble_Advertising.vcxproj” — FAILED.
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:02.01
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========February 15, 2017 at 06:18 #10418support
This is expected as GNU Make uses absolute paths in the dependency files. Please try rebuilding the project (Build->Rebuild All) instead of just building it.
February 15, 2017 at 11:04 #10422Embedded_World
i am using Rebuild Solution…but still same issue
February 16, 2017 at 05:37 #10427support
Thanks. Are you using the latest VisualGDB 5.2R8? If not, please try updating. You can also force VisualGDB to update the file references by clicking on a different MCU on the first page of VisualGDB Project Properties and then selecting the current one back and pressing “Apply”.
