Project context menu
Sysprogs forums Forums VisualGDB Project context menu
  • #7779
    Edgarus
    Hi
    I’m wondering if authors of VisualGDB could add a “Program” menu item in project context menu. It will be usefull if you have a couple of projects (embedded + c#/c++) in solution explorer, and for example embedded project is not selected as startup project. In addition, a key shortcut will be nice :).
    Best regards
    PG
    #7781
    Sure, we could add a command like that. Do you mean the equivalent of the “Program and Start Without Debugging” command in the Debug menu?
    #7785
    Edgarus
    Sure, that should do the business :).
    Best regards.
    #7797
    OK, we’ve added it to the v5.2 roadmap.
