Problems with __attribute__ directive
Sysprogs forums › Forums › VisualGDB › Problems with __attribute__ directive
  • #13014
    stefanococo
    I just ported an mbed project into VisualGDB but I’m experiencing problem using expression like this:
    const uint8_t Eeprom_area0[PAGE_SIZE] __attribute__((at(PAGE0_BASE_ADDRESS),used))={ [0 … (PAGE_SIZE-1)] = 0xFF };
    This worked well into mbed online compiler and Keil, but here in VisualGBD the compiler says at this line:
    warning :  ‘at’ attribute directive ignored [-Wattributes]
    error :  expected identifier before numeric constant
    error :  expected ‘{‘ before ‘=’ token
    error :  no match for ‘operator=’ (operand types are ‘<lambda()>’ and ‘int’)
    I’m using the latest version of VisualGDB (all extensions & toolchains updated) into VisualStudio2017.
    Thanks in advance for your help.
    Stefano
    #13017
    This is a known issue. The GCC compiler used by VisualGDB is not 100% compatible with the Keil compiler and uses a completely different syntax for placing parts of your program at fixed addresses.
    We have a detailed tutorial explaining the entire process here: https://visualgdb.com/tutorials/arm/bootloader/
    It is also worth mentioning that VisualGDB can be configured to use the Keil compiler instead of GCC. Please follow this tutorial for details:  https://visualgdb.com/tutorials/arm/keil/
