Problem with W7 + vs2k8 + 7600
Sysprogs forums Forums VisualDDK/VirtualKD discussion Problem with W7 + vs2k8 + 7600
  • #177
    I’ve installed VisualStudio 2008 Express on Win7 with 7600.16385.1 release but at VisualDDK Setup I’ve a problem,
    ntddk.h is placed here: C:WINDDK7600.16385.1INCDDKNTDDK.H, what should be the %DDKPATH% correct value?
    Giuseppe
    #1361
    Visual Studio Express does not support 3-rd party extensions. So, VisualDDK won’t work.
    #1362
    I have similar problem.
    W2K8 Srv (32bit) + VS2008 + WDK 7600.16385.1
    Tryin to setup Visual DDK 1.5 -> the setup fails to configure VisualDDK, telling
    VisualDDK has not detected either WDK or DDK.
    Well, setting the path manually won’t help
    What the clue?
    Thx in advance
    #1364
    Ok, if you just type in e.g. “C:WINDDK7600” or whatever the path is to the text box, what happens?
    #1363
    same error: it says cannot find file
    c:…inc{wntwlh…}ddkntddk.h.
    I guees the reason is, there aren’t any dedicated folders for wntwlhwxp etc anymore…
    #1365
    Le Quark
    I have the same problem.
    Win 7 x64
    WinDDk 7600.16385.1
    VS 2008 team developer edition.
    visualDDK 1.5 installer comes to the screen where DDK path or WDK path istn’t defined,
    setting the path by clicking the […] does not help.
    But if I create a variable called WDKPATH and point it to the same folder as tryed with the browse function,
    the installer is happy, and does not complain about the missing ntddk.h in none existing subfolders.
    It build win32 projects ok.
    But not x64 project, apparently the new ddk won’t accept AMD64 as an option, but needs x64 instead.
    Hope this helps.
    Regards
    Le Quark
    ‘Stig’
    #1366
    I can’t debug driver in W7+VS2008 . Can you help me ? ❓ πŸ’‘
    #1367
    It looks like recent WDKs unified ntddk.h and is not anymore inside target specific directory. Visual DDK is expecting the wrong path for ntddk.h (wxp, w2k, etc
    ) for these wdk’s
