Hi, i have loaded an exisiting makefile managed project for cross-compiling and works fine.
I did this proccess by New Project -> Linux Project Wizard -> Import a Project -> Import a project build with other tools
And finally i configured the build and target machines.
The problem is that this project has some custom targets like “make check” and “make valgrind” for running unittests and valgrind analysis. I have added both targets to custom shortcuts in
visualGDB project properties but i have some problems.
- The first one is that i get a “command not found.” error and i don’t know how to fix it. I attach custom shortcuts configuration and error log.
- The second one is that if i first run “Run tests” shortcut (the first one) and the i run “Run Valgrind” (the second one), then if i run “Run tests” again “Run valgrind” is run and i can’t run run tests until i restart visual studio.
You must be
