problem to execute on linux
Sysprogs forums › Forums › VisualGDB › problem to execute on linux
  • #6508
    hossein
    hi,
    i’m using visualgdb(trial) to build a program in visual studio for linux. i work with vs2010 and my remote machine is raspberry pi 2(raspbian installed). the program compiled built and linked successfully and i could run and debug it in vs2010. ​
    the reason i decide to use visualgdb was to make executable application for linux. because i have never exprienced linux before. so i found the executable file that visualgdb produced on remote and try to run it and i got these errors:
    /dev/video0 does not support memory mapping
    munmap: Invalid argument​​​
    unable to stop the stream .:bad file descriptor
    highgui error: v4l: could not sync to video stream. inappropriate ioctl for device
    segmentation​​​ fault
    is there any solution?
    the errors are the same for debug and release version
    and this is my code:
    #include “opencv2/opencv.hpp”
    using namespace cv;
    using namespace std;
    int main(int, char**)
    VideoCapture cap(0); // open the default camera
    if(!cap.isOpened())
    {// check if we succeeded
    cout<<“dashskgdklggkagdsa”;
    waitKey(2000);
    return -1;
    double sec;
    Mat edges;
    Mat frame;
    //vector<Vec4i> lines;
    cap >> frame;
    double test = cap.get(CV_CAP_PROP_FRAME_WIDTH);
    cap.set(CV_CAP_PROP_FRAME_WIDTH,800);
    cap.set(CV_CAP_PROP_FRAME_HEIGHT,600);
    double fps;
    namedWindow(“lines”,WINDOW_AUTOSIZE);
    namedWindow(“orig”,WINDOW_AUTOSIZE);
    for(;;)
    cap >> frame; // get a new frame from camera
    Mat gray(frame.rows,frame.cols,CV_8UC1);
    //video.write(frame);
    // imwrite(“test.bmp”,frame);
    Mat r;
    cvtColor(frame, gray, CV_BGR2GRAY);
    imshow(“orig”, frame);
    imshow(“lines”,gray);
    if(waitKey(1)>0)
    break;
    return 0;
    #6515
    ket
    Are you running the executable on the same raspberry pi 2 device or on another rasperry pi or Linux remote machine?
    As the executable was built for a rasperry pi 2 device running raspian other Linux machines have different hardware and libraries and then the program cannot run there.
    #6561
    hossein
    sorry for late reply, my hardware wrecked due to sd card corruption and i was busy with that.
    i succeeded to run the program, the problem solved when i ran it from command line(instead of clicking on it and choosing execute in terminal).
    i added two more line to extract canny edges and that worked too. then i try to add trackbar to control canny parameters but i faced the same problem. it works nice in vs2010 in local computer but on the raspberry pi 2 i have this errors:
    HIGHGUI ERROR: V4L: Property <unknown property string>(6) not supported by device
    (lines:2929): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-label-select-on-focus after class was initialised
    Segmentation fault
    #6569
    hossein
    any idea?
    is there anyone working with raspberry pi?
    #6576
    It looks like some sort of an incompatibility problem between your device and your toolchain. Please double-check the following:
    • Ensure that your toolchain is compatible with the image version on your Raspberry Pi
    • Ensure that you have re-synchronized the sysroot of your toolchain with the device
    If nothing helps, please try compiling your program directly on Raspberry Pi and let us know if that works.
