Sysprogs forums › Forums › VisualGDB › Problem in compiling ARM code in Visual GDB
- This topic has 3 replies, 2 voices, and was last updated 12 years, 6 months ago by
rocky234.
April 4, 2014 at 09:53 #776
rocky234
I am new to visual GDB environment .
I want to run arm code in android project in visual GDB, where my C-code call’s the arm function.
I have created a normal android project as shown in visual GDB site.Problem:-
1)The visual GDB is not recognizing the functions names(in .s file ) and nor the arm instructions.
For instruction it is coming as BAD instruction .
compiler i missed some compiler option or selection?2)Is their any mistake in make file ?
3) Which tool chain should I use to compile ARM code 4.6/4.8/clang3.3
kindly do the need full help…..
April 4, 2014 at 19:00 #3031ket
1), 2) You may need additional flags or includes in the makefile. It is not clear what the exact issue here is, please post the build log from the Output window showing the errors and a screenshot of how you are calling the arm instructions.
3) Either of these toolchains is available for ARM and hence will compile fine for ARM. If you wish to compile for ARM only, then change the ABI of the application to armeabi and/or armeabi-v7a. This way the app will not be built for other platforms.April 5, 2014 at 05:28 #3032rocky234
ParticipantHi ,
i have pasted the .s file,error message and make file…kindly go through the same.
ARM_ASM_CODE is a macro which switch’s between the c-code and arm code .and about the flags in make file…
kindly check which all flags to be include in make file and let me know….plz do the need full help
bac.s
CODE32
AREA IAREAC,CODE,READONLYFunction_1 PROC
STMFD sp!,{r4-r8,lr}LDR r4, [r1]
LDRB r7, [r3];some code
LDR lr, |Table1|
MOV r5, r8, ASL r5 ;r5 = b
RSB r8, r5, r4 ;a -= b;some
MOVHI r0, r7
LDMFDHI sp!, {r4-r8, pc}LDRB r3, [r4, #0]
LDRB r5, [r4, #1]
LDRB lr, [r4, #2]
ADD r4, r4, #3
STR r4, [r2, #40]
ADD lr, lr, r5, ASL #8
ADD lr, lr, r3, ASL #16;some code
ADD lr, lr, r12, ASL #24
STR lr, [r0,#0]MOV r0, r7
LDMFD sp!,{r4-r8, pc}|Table1|
DCD array1|Table2|
DCD array2IMPORT array1
IMPORT array2EXPORT Function_1
END
ERROR
1> [armeabi-v7a] Compile thumb : jniplayer <= bac.s
1> jni/jniplayer/bac.s: Assembler messages:
1>C:folderProjectjnijniplayerbac.s(6): error : bad instruction `code32′
1>C:folderProjectjnijniplayerbac.s(7): error : bad instruction `area IAREAC,CODE,READONLY’
1>C:folderProjectjnijniplayerbac.s(9): error : bad instruction `Function_1 PROC’
1> jni/jniplayer/bac.s:17: Warning: missing operand; zero assumed
1> jni/jniplayer/bac.s:23: Warning: missing operand; zero assumed
1>C:folderProjectjnijniplayerbac.s(25): error : bad instruction `a -=b’
1>C:folderProjectjnijniplayerbac.s(42): error : bad instruction `ldmfdhi sp!,{r4-r8,pc}’
1>C:folderProjectjnijniplayerbac.s(76): error : junk at end of line, first unrecognized character is `|’
1>C:folderProjectjnijniplayerbac.s(77): error : bad instruction `dcd TabLE1′
1>C:folderProjectjnijniplayerbac.s(79): error : junk at end of line, first unrecognized character is `|’
1>C:folderProjectjnijniplayerbac.s(80): error : bad instruction `dcd TabLE2′
1>C:folderProjectjnijniplayerbac.s(83): error : bad instruction `import TabLE1′
1>C:folderProjectjnijniplayerbac.s(84): error : bad instruction `import TabLE2′
1>C:folderProjectjnijniplayerbac.s(86): error : bad instruction `export Function_1′
1> jni/jniplayer/bac.s.s:77: Warning: partial line at end of file ignored
1> make.exe: *** [obj/local/armeabi-v7a/objs-debug/jniplayer/bac.s.o] Error 1make file
LOCAL_PATH := $(call my-dir)
# jniplayer.so
include $(CLEAR_VARS)ifeq ($(TARGET_ARCH_ABI), armeabi-v7a)
#staticlib: $(LIB)#CC := armcc
#AR := ar
#AS := as
LENT_CFLAGS := -DARCH_ARM=1 -DHAVE_NEON=1 -DARM_ASM_CODE=1
#OBJDIR_ASM := obj_asm
endif
ifeq ($(TARGET_ARCH_ABI), x86)
LENT_CFLAGS := -DARCH_X86_32=1
endifLOCAL_C_INCLUDES += $(LOCAL_PATH)/../lenthevcdec/ $(LOCAL_PATH)/../../../../../../ $(LOCAL_PATH)/../ffmpeg-2.0/ $(LOCAL_PATH)/../jniplayer/
LOCAL_SRC_FILES := jniplayer.cpp jni_utils.cpp yuv2rgb565.cpp gl_renderer.cpp f1.c f2.c
LOCAL_SRC_FILES := bac.s cas.s
LOCAL_LDLIBS := -llog -lz -ljnigraphics -lGLESv2 #-larmar_lib
OBJS_ASM := ${LOCAL_SRC_FILES:%.s=%.o}
OBJS_ASM := ${OBJS_ASM:%=$(OBJDIR_ASM)/%}LOCAL_CFLAGS += $(LENT_CFLAGS)
LOCAL_CFLAGS += -mfpu=neon
#LOCAL_CFLAGS += CC := gcc
#LOCAL_CFLAGS += AR = ar
#LOCAL_CFLAGS += armccLOCAL_SHARED_LIBRARIES := ffmpeg lenthevcdec
LOCAL_MODULE := jniplayer
include $(BUILD_SHARED_LIBRARY)
April 5, 2014 at 22:02 #3030ket
The compiler does try to build your .s file as assembly code, so you should not need any additional flags.
In your Android.mk file, you are overriding the LOCAL_SRC_FILES to contain only the .s files and not the .cpp and .c files because you are using := not +=. If you intend to build both assembly and c/c++ files for your app, then the second LOCAL_SRC_FILES definition should use += to append files instead.
As for the errors in your assembly file bac.s, they seem to be pointing to actual problems with this file. You are using unknown instructions and unknown syntax in this file. You should be using gcc ARM assembly syntax here for gcc to be able to compile this file not just ARM assembly syntax.
