Sysprogs forums › Forums › VisualGDB › Problem in assemble .s files in project?
- This topic has 3 replies, 2 voices, and was last updated 8 years, 11 months ago by
February 10, 2017 at 03:17 #10354
FesianXu
ParticipantHi!
I am new to VisualGDB,recently i new a stm32 stand-alone project in VisualGDB, any cpp or c files can be compiled correctly.But when i migrate UCOSII into the project, i found that os_cpu_a.s cannot be correctly assembled.Error log is shown as follows:
<h6>1> ../UCOSII/PORT/os_cpu_a.s: Assembler messages:
1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(9): error : bad instruction `import OSRunning'</em>
<em> 1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(9): error : bad instruction `external references’
1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(10): error : bad instruction `import OSPrioCur'</em>
<em> 1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(11): error : bad instruction `import OSPrioHighRdy’
1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(12): error : bad instruction `import OSTCBCur'</em>
<em> 1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(13): error : bad instruction `import OSTCBHighRdy’
1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(14): error : bad instruction `import OSIntNesting'</em>
<em> 1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(15): error : bad instruction `import OSIntExit’
1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(16): error : bad instruction `import OSTaskSwHook'</em>
<em> 1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(18): error : bad instruction `export OSStartHighRdy’
1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(19): error : bad instruction `export OSCtxSw'</em>
<em> 1>C:\Users\Administrator\Desktop\ucos_in\ucos_in\..\UCOSII\PORT\os_cpu_a.s(20): error : bad instruction `export OSIntCtxSw’</h6>
(here i only list part of them:) )It seems that compiler didnt recognize those instruction?
And my makefile setting shown as follows:
<h6>CFLAGS: -mcpu=cortex-m3 -mthumb</h6>
<h6>LDFLAGS: </h6>
<h6>ASFLAGS: -mcpu=cortex-m3 -mthumb</h6>
<h6>Common Flags: -mcpu=cortex-m3 -mthumb</h6>
<h6>Defines: ARM_MATH_CM3 STM32F103ZE stm32_flash_layout STM32F10X_HD</h6>
I am no sure whether my setting is right or not, please give me some suggestions.Any help will be appreciated!
February 11, 2017 at 00:06 #10368support
You might be using assembly files that are intended for a different compiler (e.g. Keil or IAR). Unfortunately unlike C/C++, the syntax of the assembly files is totally different for the different compilers (mainly when it comes to special directives, declaring symbols, etc) and they are not compatible with each other. Please double-check that your codebase contains a version of the assembly files that is compatible with GCC.
February 11, 2017 at 03:12 #10376FesianXu
ParticipantThanks for your kindly help!I have an additional question.Are there any methods to replace visualGDB’s compiler with Keil’s compiler?Thansk in advance!
February 11, 2017 at 21:38 #10378support
Yes, we actually have a detailed tutorial showing how to use VisualGDB with Keil: https://visualgdb.com/tutorials/arm/keil/
