Sysprogs forums › Forums › VisualGDB › Problem: ESP32 Wroom with OpenOCD
- This topic has 11 replies, 5 voices, and was last updated 8 years, 10 months ago by
ASH74.
May 31, 2017 at 14:57 #11350
ericl
ParticipantHello,
I’m using VisualGBD with an ESP32 Wroom and an Olimex ARM-USB-OCD-H.
So far it was working fine, I was able to flash and debug, but since yesterday I got an error while trying to flash.
The Ouput is below (seems CPU1 is not halted). Any idea?
Open On-Chip Debugger 0.9.0 (2017-05-09)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select <transport>’.
adapter speed: 3000 kHz
Info : clock speed 3000 kHz
Info : esp32.cpu0: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32.cpu0: Core was reset (pwrstat=0x5F, after clear 0x0F).
Interrupt suppression during single-stepping is now enabled
Info : esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32.cpu0: Target halted, pc=0x40000400
Warn : esp32.cpu1: target not halted
in procedure ‘reset’
in procedure ‘ocd_bouncer’
in procedure ‘ocd_process_reset’
in procedure ‘ocd_process_reset_inner’ called at file “embedded:startup.tcl”, line 248
in procedure ‘esp32.cpu0’ called at file “embedded:startup.tcl”, line 349
in procedure ‘ocd_bouncer’esp32.cpu0: target state: halted
Target did not halt within 5000 msecInfo : esp32.cpu0: Target halted, pc=0x40090DF8
Info : dropped ‘gdb’ connectionMay 31, 2017 at 18:38 #11352vard
ParticipantNot sure if you’ve read this, some good information here: LIMITATIONS OF THE ESP32 DEBUGGING
May 31, 2017 at 22:44 #11356ericl
ParticipantThanks for the info. I tried doing the procedure when the flash is not programmed. But at step 2 I cannot get the memory programmed. When it is said to do “Start JTAG debugging”, I do “Start debugging with GDB” but I get the same error: Warn : esp32.cpu1: target not halted.
Am I missing something?
June 1, 2017 at 05:42 #11362support
Just to double-check, are you using the latest esp32-gcc5.2.0.exe toolchain? A recent update to the ESP-IDF was interfering with the FLASH programming and it was only fixed in the 5.2.0 toolchain.
June 5, 2017 at 07:53 #11398satau
ParticipantI’m having what appears to be the same problem. I have not succeeded in flashing the ESP32 at all. VisualGDB-5.2r9. I have manually installed the esp32-gcc5.2.0.exe toolchain and recompiled the project, this did not help. I’m using the TUMPA JTAG interface. Any suggestions?
Open On-Chip Debugger 0.9.0 (2017-05-09) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html none separate Info : auto-selecting first available session transport "jtag". To override use 'transport select <tra nsport>'. adapter speed: 3000 kHz Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED Info : clock speed 3000 kHz Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0 x1) Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0 x1) Info : esp32.cpu0: Target halted, pc=0x40090DF8 Error: The 'mww' command must be used after 'init'. in procedure 'init' in procedure 'ocd_bouncer' in procedure 'flash' in procedure 'ocd_bouncer' Info : accepting 'gdb' connection on tcp/3333 Interrupt suppression during single-stepping is now enabled Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0 x1) Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0 x1) Info : esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F). Info : esp32.cpu0: Target halted, pc=0x40000400 Warn : esp32.cpu1: target not halted in procedure 'reset' in procedure 'ocd_bouncer' in procedure 'ocd_process_reset' in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 248 in procedure 'esp32.cpu0' called at file "embedded:startup.tcl", line 349 in procedure 'ocd_bouncer' esp32.cpu0: target state: halted Target did not halt within 5000 msec
June 6, 2017 at 04:39 #11402support
This could be caused by the ESP32 configuration, or by incompatibility with TUMPA (we do not officially support it and have not heard of anyone successfully using it). The easiest way to get it to work would be to get the same hardware as shown in our tutorials and ensure your wiring 100% matches the one shown there. Once you get it to work, it would be easier to switch the debug adapter (or the ESP32 board) and quickly pinpoint what exactly is causing the problem.
June 7, 2017 at 06:15 #11406ASH74
ParticipantI ran into a similar issue with one of my dev-c boards that had image configured to run FreeRTOS on the first core only.
This is the output from openocd when I try to download & debug my code where the previous image was configured to run on the first core only.
in procedure ‘ocd_bouncer’I have a parallel install of the esp-idf via MSYS2 where I was able to flash one of the examples to the board that did not have “Run FreeRTOS only on first core” set and then I was able to debug my code in VisualGDB.
It was this thread that got me past this issue https://www.esp32.com/viewtopic.php?t=1253. I’m not sure if this is the same issue for you but I can recreate the openocd output above by having an image that runs only on the first core and then try to debug my code in VisualGDB.
June 7, 2017 at 06:36 #11407satau
ParticipantThanks for the reply. I have switched out the ESP32 DevKitC board for a brand new one – I’m seeing the same issue. Unfortunately I don’t have another JTAG interface, and it could be a costly exercise to purchase and try multiple interfaces until it (hopefully) works. Can you link me a list of supported models?
The original poster is using an Olimex interface and seeing a similar error – ‘cpu1 not halted’. So although this doesn’t rule out a TIAO TUMPA specific issue, I’m hoping that someone who has seen this problem before can jump in and help out.
More detailed logs from the OpenOCD window are below:
mon reset halt &"mon reset halt\n" @"JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n" @"JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n" @"esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F).\n" @"esp32.cpu0: Target halted, pc=0x40000400\n" @"esp32.cpu1: target not halted\n" @"in procedure 'reset' \n" @"in procedure 'ocd_bouncer' \n" @"in procedure 'ocd_process_reset' \n" @"in procedure 'ocd_process_reset_inner' called at file \"embedded:startup.tcl\", line 248\n" @"in procedure 'esp32.cpu0' called at file \"embedded:startup.tcl\", line 349\n" @"in procedure 'ocd_bouncer'\n" @"\n" @"esp32.cpu0: target state: halted\n" ^done restore C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin binary 0x40090000 0 0xe14 &"restore C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin binary 0x40090000 0 0xe14\n" ~"Restoring binary file C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin into memory (0x40090000 to 0x40090e14)\n" ^done mon esp108 run_alg 0x400902d0 0x40090df8 20000 a1=0x3ffd0404 a10=0 a11=4096 a12=0 a0 pc &"mon esp108 run_alg 0x400902d0 0x40090df8 20000 a1=0x3ffd0404 a10=0 a11=4096 a12=0 a0 pc\n" @"Target did not halt within 20000 msec\n" @"\n" @"esp32.cpu0: Target halted, pc=0x40090DF8\n" @"esp32.cpu0: target state: halted\n" ^done mon reset halt &"mon reset halt\n" @"JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n" @"JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n" @"esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F).\n" @"esp32.cpu0: Target halted, pc=0x40000400\n" @"esp32.cpu1: target not halted\n" @"in procedure 'reset' \n" @"in procedure 'ocd_bouncer' \n" @"in procedure 'ocd_process_reset' \n" @"in procedure 'ocd_process_reset_inner' called at file \"embedded:startup.tcl\", line 248\n" @"in procedure 'esp32.cpu0' called at file \"embedded:startup.tcl\", line 349\n" @"in procedure 'ocd_bouncer'\n" @"\n" @"esp32.cpu0: target state: halted\n" ^done restore C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin binary 0x40090000 0 0xe14 &"restore C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin binary 0x40090000 0 0xe14\n" ~"Restoring binary file C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin into memory (0x40090000 to 0x40090e14)\n" ^done mon esp108 run_alg 0x400902d0 0x40090df8 20000 a1=0x3ffd0404 a10=0 a11=4096 a12=0 a0 pc &"mon esp108 run_alg 0x400902d0 0x40090df8 20000 a1=0x3ffd0404 a10=0 a11=4096 a12=0 a0 pc\n" @"Target did not halt within 20000 msec\n" @"\n" @"esp32.cpu0: Target halted, pc=0x40090DF8\n" @"esp32.cpu0: target state: halted\n" ^done mon reset halt &"mon reset halt\n" @"JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n" @"JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n" @"esp32.cpu0: Core was reset (pwrstat=0x1F, after clear 0x0F).\n" @"esp32.cpu0: Target halted, pc=0x40000400\n" @"esp32.cpu1: target not halted\n" @"in procedure 'reset' \n" @"in procedure 'ocd_bouncer' \n" @"in procedure 'ocd_process_reset' \n" @"in procedure 'ocd_process_reset_inner' called at file \"embedded:startup.tcl\", line 248\n" @"in procedure 'esp32.cpu0' called at file \"embedded:startup.tcl\", line 349\n" @"in procedure 'ocd_bouncer'\n" @"\n" @"esp32.cpu0: target state: halted\n" ^done restore C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin binary 0x40090000 0 0xe14 &"restore C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin binary 0x40090000 0 0xe14\n" ~"Restoring binary file C:/SysGCC/esp32/esp32-bsp/sysprogs/flashprog/ESP32FlashProg.bin into memory (0x40090000 to 0x40090e14)\n" ^done mon esp108 run_alg 0x400902d0 0x40090df8 20000 a1=0x3ffd0404 a10=0 a11=4096 a12=0 a0 pc &"mon esp108 run_alg 0x400902d0 0x40090df8 20000 a1=0x3ffd0404 a10=0 a11=4096 a12=0 a0 pc\n" @"Target did not halt within 20000 msec\n" @"\n" @"esp32.cpu0: Target halted, pc=0x40090DF8\n" @"esp32.cpu0: target state: halted\n" ^done
This reply was modified 8 years, 10 months ago by
satau.
June 7, 2017 at 06:41 #11409satau
ParticipantASH74: I was able to flash one of the examples to the board that did not have “Run FreeRTOS only on first core” set and then I was able to debug my code in VisualGDB.
Awesome. I’ll give that a try and see if it helps. Thanks for sharing!
June 7, 2017 at 10:03 #11410satau
ParticipantI can confirm that everything is working fine after flashing a program that enables dual core mode. Thankyou ASH74!
Mods – It may be worth noting the following:
- If ESP32 is running in single core mode, cpu1 will fail to halt when attempting to program/debug via JTAG using VisualGDB.
- The TIAO/TUMPA JTAG interface appears to be working fine using the VisualGDB bundled drivers – flashes ok and is hitting breakpoints when running code.
June 7, 2017 at 18:43 #11415support
Thanks for confirming this, we will note down that TUMPA is compatible with ESP32.
Regarding single-core mode, you can actually try editing the <SysGCC>\esp32\esp32-bsp\OpenOCD\share\openocd\scripts\target\esp32.cfg file (uncomment the set ESP32_ONLYCPU 1 line), although we have not fully tested this mode and it may result in strange bugs.
June 10, 2017 at 15:44 #11451ASH74
ParticipantSatau,
this is good news that it fixed your issue, I spent a few hours trying to figure it out, one board was ok, the second one did not work.Cheers!
