I didn’t get any of those options for that key. All i could do was the delete the key (which was called Default) to remove bizas info. Then searched registry deleting anything with bizas in it
Seems to have cleared it. What else is in the registry i need to delete?
Why can’t you just finish the installer. My registry is full off stuff now. The only reason I knew this was because of the “Select drive…” right click menu
after uninstalling i also still have it in the context menu. i took me some time to remove the rest manually, even how to remove the driver in inf folder i had to search how to get rit of it. why can’t you make a proper clean uninstall?? this is ridiculous and totally unneccessary.
