I’m debugging the ESP32 using OpenOCD. I did a program with 5 task created, that works without any problem until I try to insert a breakpoint.
In that case, I often get an error (Received a SIGINT: Interrupt:
and my Inline GDB Stub Output:
cpu0: esp32_fetch_all_regs (line 234): DSR (8000CC13) indicates DIR instruction generated an exception!
Target halted. PRO_CPU: PC=0x400D2587 (active) APP_CPU: PC=0x80004801
The target is not in the halted nor running stated, stepi/continue ignored.
), the program resets and I find myself in the “esp_vApplicationIdleHook()” task, and I can’t go on debugging.
The problem seems to be related to the breakpoint stop, because otherwise the program keeps increasing my counter without any error. What could it be related? It seems like a watchdog that can’t be stopped in time.
Thank you,
Mattia
