Sysprogs forums › Forums › VisualGDB › Not able to build at command line using MSbuild
- This topic has 5 replies, 2 voices, and was last updated 6 years, 3 months ago by
January 3, 2020 at 18:23 #26970
pydinag
ParticipantHi
I have installed visual studio 2019, msbuild 2019 tools and Visual GDB in windows 10 machine.
I have created hello world linux project for beaglebone using VisualGDB and visual studio 2019. I am able to build the project using visual studio IDE.
Then i am try to build at command line using following msbulid but i am getting following error. Please help me to resolve this issue.
:\WINDOWS\system32>msbuild C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.sln /p:Configuration=Release /p:Platform=VisualGDB
Microsoft (R) Build Engine version 16.4.0+e901037fe for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.Building the projects in this solution one at a time. To enable parallel build, please add the “-m” switch.
Build started 1/3/2020 10:25:45 PM.
Project “C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\B
egaleTestApp.sln” on node 1 (default targets).
ValidateSolutionConfiguration:
Building solution configuration “Release|VisualGDB”.
egaleTestApp.sln” (1) is building “C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineerin
g\Source\RsDetectionVgdb\BegaleTestApp.vcxproj” (2) on node 1 (default targets).
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Current\Bin\Microsoft.Common.CurrentVersion.targ
ets(775,5): error : The OutputPath property is not set for project ‘BegaleTestApp.vcxproj’. Please check to make sure
that you have specified a valid combination of Configuration and Platform for this project. Configuration=’Release’ P
latform=’VisualGDB’. You may be seeing this message because you are trying to build a project without a solution file,
and have specified a non-default Configuration or Platform that doesn’t exist for this project. [C:\Jenkins\workspace\
PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.vcxproj]
Done Building Project “C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsD
etectionVgdb\BegaleTestApp.vcxproj” (default targets) — FAILED.Done Building Project “C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsD
etectionVgdb\BegaleTestApp.sln” (default targets) — FAILED.Build FAILED.
“C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTes
tApp.sln” (default target) (1) ->
tApp.vcxproj” (default target) (2) ->
(_CheckForInvalidConfigurationAndPlatform target) ->
rgets(775,5): error : The OutputPath property is not set for project ‘BegaleTestApp.vcxproj’. Please check to make sur
e that you have specified a valid combination of Configuration and Platform for this project. Configuration=’Release’
Platform=’VisualGDB’. You may be seeing this message because you are trying to build a project without a solution fil
e, and have specified a non-default Configuration or Platform that doesn’t exist for this project. [C:\Jenkins\workspac
e\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.vcxproj]0 Warning(s)
1 Error(s)Time Elapsed 00:00:00.41
C:\WINDOWS\system32>
January 3, 2020 at 18:50 #26971pydinag
ParticipantPlease find the project folder for your reference
You must be logged in to view attached files.January 3, 2020 at 20:02 #26973support
Based on the error message you shared, it looks like VisualGDB is not installed on the machine you are using to build the project.
Please ensure VisualGDB is installed and activated on the user account used to run the automated builds.
Please feel free to look through the following tutorial for a detailed step-by-step example: https://visualgdb.com/tutorials/ci/tfs/
If you can confirm that VisualGDB is installed, please try building the solution using devenv.exe, not msbuild.exe (see this page).
January 4, 2020 at 06:18 #26974pydinag
I already installed VisaulGDB in the machine where i am trying to build the project. Using visual studio IDE i am able to build the project.
As per your suggestion, i try to build using devenv but i am getting an error: Kindly help me to resolve this issue.
C:\Users\312005216>devenv C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.sln /build Release | VisualGDB /project C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.vcxproj /projectconfig Release | VisualGDB
‘devenv’ is not recognized as an internal or external command,
operable program or batch file.January 4, 2020 at 07:07 #26975pydinag
ParticipantHi
I added the devenv path to system environmental variables. After that the error ” devenv is not recognized as an internal or external command” is not coming.
Now i am getting following error:
C:\WINDOWS\system32>devenv C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.sln /build Release | VisualGDB /project C:\Jenkins\workspace\PanaFlow\Test_RS_Detection\AII_Based_FlowMeasurement\Engineering\Source\RsDetectionVgdb\BegaleTestApp.vcxproj /projectconfig Release | VisualGDB
‘VisualGDB’ is not recognized as an internal or external command,
operable program or batch file.January 4, 2020 at 17:25 #26976support
KeymasterPlease try using the following syntax:
/projectconfig "Release|VisualGDB"
Note the quotes and no spaces.
