In case anyone is interested in using the Thread and Zigbee SDK with VisualGDB it turns outs to be fairly simple. The main SDK and Thread and Zigbee SDK are very similar. The basic steps are below. If there turns out to be any interest I could probably throw together a more specific tutorial.
- Copy the thread, zigbee, and 802.15.4 directories to the corresponding BSP directories. There are a couple of other additional directories that may need to be copied as well.
- Copy the thread and zigbee linker scripts into the BSP directory (Optional, just replace contents of local project linker script).
- Include the thread/zigbee directories in your project as needed.
- Include the appropriate libraries by name (ie. zboss.a)
At this point you should be able to copy one of the examples into your project and it should compile (once you satisfy any missing dependencies). You will need to use the example’s sdk_config.h, not the one included in your project.
